Headlights
Highway
Ky
Looking at some headlights for my 2013 express,and in the headlight description it says wont work with projection headlights. I am assuming the ‘13 is projector lights ? If so is this something that Alpha OBD can correct?… ok just checked and mine are reflector style
'13 was the first year for the projector headlights, the reason why they state not compatible is the plug on the projectors is different from what's on the reflector style.
Lots of members have Alpharex headlights and really like them(me included). They offer many styles and even ones that are all LED.
There are even adapters to go from projector to reflector style headlights or even reflector to projector style if you want to run the OEM projectors.
H
Highway
Ky
This is mine, is it the projector type ?
Burn2k12Ram
Reno, Nevada
So I have a 2012 Outdoorsman with Quads(Projectors), would I need an adapter to run these Alpharex's? Just bought a bunch of LED's so would like to run LED's across the board. Got a pic of yours?
@Burn2k12Ram you won't need an adapter for the Alpharex. I have the Original Pro Series V1, they don't have the sequential turn signals(wasn't available when I bought mine) Like the Alpharex G2 Pro version. They both use H7 bulbs for the High and Low beams. If I was going to buy them again I would get the Luxx version with built in LEDs, people have reported they're better than using LED bulbs in the Pros
I also added the Dedicated DRL wiring to my truck so the top brow light works like the factory DRLs.
Burn2k12Ram
Reno, Nevada
Those look freaking awesome. Seriously leaning towards them. Thanks so much
SeaRefractor
Normandy Park, WA
I have the AlphaRex headlights as well. For the H7 bulbs replacement to LED (I had not purchased the Luxx version), I went with the following as they are the same size dimensions as the H7 halogen bulbs and require no modifications of any kind, in addition are non-polarity so you don't have to worry about plugging them in backwards and having to take the headlight off again to reverse the connections.
Canadianbreed
Canada
2500 outdoorsman 5.7
Morimoto or Alpharex are both reputable when it comes to aftermarket lighting, I personally own the morimoto XB amber headlights + taillights which I've had for 3 months so far and love em!
capebreton1967
