Heads and casting numbers
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
Good day,
Wanting to check if I require the same casting number on my current Hemi heads in order to change them out with another set of heads running the same build years? I have the 2011 and I believe my years run from 2009-12 if I’m correct? If not please correct me. Can I just swap any 4th Gen heads? I get a good look at the numbers as the gaskets are blocking my view. Thanks for any input.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Good day,
Any Eagle head hemi from 2009 and newer will fit your block.
