4xdad
- Joined
- Feb 18, 2021
- Posts
- 1,759
- Reaction score
- 1,694
- Location
- Edmonton Alberta
- Ram Year
- 2015 powerwagon
- Engine
- 6.4
If it’s a chronic problem you could put a filter in line easily
Start the truck and get it fully up to operating temperature.Over the last several weeks I have noticed the air coming out of my heater is just barely warm. Turned the temp setting as high as it will go but I don't seem to be getting much heat. Surely don't have a clogged heater core already? Possibly something in the electronics is not telling it the temp I set it at?
Truck is a 2016 2500 6.4 with 40,000mi.
My solution for chronic heat loss on a 2002 Ram with the 4.7 was to remove the rear most "freeze" core plugs from the block, then douche the coolant passages of the block wit a garden hose and a high pressure nozzle.It’s not the blend doors it’s the heater core plugs up. I have flushed my heater core out every three weeks through the cold season. I get heat for 2 1/2 three weeks and then it stops until you hit a really big bump sometimes that’ll jar some of the sand out. What I’d like to know is why First second why doesn’t ram warranty this crap and third is there someway to put a filter system on these trucks to stop that sand from going through the core
Turn the heat up fully and raise the hood and feel the heat of the 2 heater hoses... carefully.
If there is a big difference in their temperature, i.e. one is cooler than the other, there id inadequate flow through the core.
If they are equally hot, the problem is in the HVAC air distribution inside the cab. There ya go!
I have read about this method. Any issues with corrosion internally from using tap water? Can't get it all out. Guess on a 20 year old motor, who cares.My solution for chronic heat loss on a 2002 Ram with the 4.7 was to remove the rear most "freeze" core plugs from the block, then douche the coolant passages of the block wit a garden hose and a high pressure nozzle.
After I did it, I was filthy; covered in crud from inside the block. The customer never had any more trouble.
