fonzyn75
- Oct 19, 2012
- 236
- 74
- 2008
- 6.7 Cummins
any luck?
any luck?
So looks to have been a loose relay/fuse, wonder why the dealership didn't even check that. Seems to have been a simple fix. Really annoying when they don't even look.
Yeah they are pilot driving lights, I put them in, there are some hella ones that fit there as well I believe.
Unfortunately, it failed to start again last evening. I turned it off, opended the hood and relay/fuse box lid and re-seated all of the fuses and relays. Most of them didn't seem to move much. I closed it back up, and it started.
Now that you know where it's time to find out which one. Next time it does this try pushing one at a time and start in between each relay. Now that you know where it's time to find out which one. Next time it does this try pushing one at a time and start in between each relay.
Have we tried disconnecting the battery? Then trying to start after you reconnect the battery.
Dig deeper into the PDC and check for burnt/loose connections.
Do one at a time to isolate the problem.
man it just sucks to see this. Have you taken it to a different dealer?
