Hello, please help if you can . . .
D
dodge29
Pa
Continued starting again today, all day.
D
dodge29
Pa
Good idea, will give that a try tonight, thanks!
D
dodge29
Pa
It continues starting every day. I wont report back here again unless it fails to start in the near future. Thanks for the excellent help.
D33k
Las Vegas
So looks to have been a loose relay/fuse, wonder why the dealership didn't even check that. Seems to have been a simple fix. Really annoying when they don't even look.
D
dodge29
Pa
I know I said I was done here, but! Hey D33K, where'd you get those fog lights that fit into the wide section of the bumper slot? Very nice, are they aftermarket?
Thanks.
D33k
Las Vegas
Yeah they are pilot driving lights, I put them in, there are some hella ones that fit there as well I believe.
D
dodge29
Pa
Unfortunately, it failed to start again last evening. I turned it off, opended the hood and relay/fuse box lid and re-seated all of the fuses and relays. Most of them didn't seem to move much. I closed it back up, and it started.
HolyRamBatman
Deep in the Heart of Texas
:shocked: Now that you know where it's time to find out which one. Next time it does this try pushing one at a time and start in between each relay.
Have we tried disconnecting the battery? Then trying to start after you reconnect the battery.
Dig deeper into the PDC and check for burnt/loose connections.
Do one at a time to isolate the problem.
D
dodge29
Pa
Can I get to the TIPM without special tools? I know it's in the bottom half of the fuse box.
D
dodge29
Pa
It failed to start again today.
quietpeen
2021 TRX
Hellcat
man it just sucks to see this. Have you taken it to a different dealer?
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Unbelievable jeep going in that is insane.
$miley
D
dodge29
Pa
Not yet. It's the same story at any Dodge dealer. If it doesn't exhibit the symptom for them they want look at it. Its intermittent, So we'll just drive it till it fails, I guess. I don't know that I have any other course of action I could take.
D
dodge29
Pa
Still failing to start every 4 or 5 days.
Reticle918
