seekAmanitah
Did a motor swap over Thanksgiving break. Had my younger brother help me to get his feet wet in mechanic work. Anyways, we put the rubber hoses back on the transmission for the coolant circulation but somehow never got them clamped. Of course one started leaking after a day of driving and I can't get to it to clamp them.
There is a box on the driver side of the trans under where the lines connect. I started to remove it till I notice some trans fluid coming out. I tightened back up. It looks like if I took this box off I could get to the lines. Although I would loose fluid. Is the best route to take it off and just fill it up afterwards? Maybe just drain it altogether and fill it back up afterwards? Of there another way that is better?
