help, please
cwatson
4.7L V-8
I have a 2009 Dodge Ram. Recently, I will hear a loud knocking noise behind the dash and my air conditioner and heater will ONLY blow out at the feet! Does anybody know where I need to start with this issue, or have experienced this themselves? With the TX summer around the corner, I need to get this thing taken care of.
Thank you!
MADDOG
Living in a Firepit
6.4L HEMI
Yes, it's a common failure. The HVAC blend door and/or motor is starting to fail.
1500ram12
5.9L Cummins
my thoughts exactly
quietpeen
2021 TRX
Hellcat
Do you have any warranty left ? If it is the blend door I think the dash has to cOme out to get to it
jake09
Blend door activator needs to be replaced
reefguy89
laurel de
wtf this is a problem on the 4th gens to. Shouldnt dodge have came out with a better design by now.
shadango
Pittsburgh, PA
I was thinking the same thing.....I know the blend door issue was a common problem on durangos//dakotas too, (like my 2003 Durango I traded in)
The power wires for the blower were also common trouble areas.....melting at the blower plug. Wonder if that is an issue on the 4th gen rams too?
Drew78
Mabank, (east) Texas
I know this is an old thread but my truck just started this this morning and was wondering if this is an easy fix and/or a cheap fix. Thanks
Jeepkid
Puyallup WA
2010 Dodge Ram 1500 TRX 4
My truck just started blowing cold air on my feet this morning and with it being 25 degrees out this isnt gonna pass.
Is this a warranty thing? ive got an appointment with the dealer wednesday to get this looked at and i wont be payng to have them check it when i know whats wrong.
ramhunter9
P-Star Jeep Wrangler
Replace the t-stat
ramhunter9
If you are not getting any heat anywhere it's the t-stat. And yes it's under the hood. Easy to change drain some coolant. There is a shut off valve under the radiator driver side. Drain it in a clean bucket. Drain just enough that the radiator hose holds zero fluid. Take off the 2 screws at the end of the hose going to the block. Inside is the t-stat. Replace with a 15 dollar napa gold stat. Put all back together and put the fluid back in the radiator.
Now this is only if you are getting zero heat. Meaning the stat is not opening and closing like it should.
Had to do this a time or two in my old rams b
Jeepkid
Puyallup WA
He says his is blowing cold on feet. mine does the same thing but wont switch to any other setting
ramhunter9
Then your screwed. See above post.
partsguy
SHREVEPORT LA
HEMI 5.7
if its an 09 you may have an open recall for the acutators and a flash for the ac control head. call a dealer with your vin or in box me and i may be able to find out for you
99RamSport360
5.9L Magnum 360
Ram - Dodge
This is a company who made a DIY kit for the HVAC blender door problem, all you have to do is cut a slot, pull out the old one, put in the new one, and seal it back up.
The new door is all metal and has a metal hinge, so you don't have to worry about it warping or the hinge breaking. They have kits for 2nd and 3rd gens. (link above)
