Help! Rough Idle is back.
RompinRam
Hoffman Estates, IL
4.7 Magnum
Alright, well my rough idle is back on my 4.7L. Before I fixed it by replacing my TPS. Not sure what is causing it now. But since it has gotten bad again my truck has died 4 times. Mostly when shifting into reverse or park from drive. My buddy who has a shop looked it over and can't find anything wrong with it. He said he thinks it needs a PCM flash. Said there was a Technical Service Bulletin on rough idle for a PCM Flash. Anybody else hear anything about this, or know of anything else I can try before paying for a reflash.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Is it throwing any codes?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I would call the dealership and ask them if there is an updated flash for this problem. They should be able to tell you before you go in and pay for something you dont need.
RompinRam
RompinRam
Hoffman Estates, IL
4.7 Magnum
Well just talked to the dealership. He said it should've been flashed when it left the dealership. And for a 9 year old truck it's probably something else causing the problem.
GhostRam94
Hunstville, Texas
2009 Laramie CC
hmmm how is your tb looking??? when is the last time you changed your plugs?? wanna try seafoam??
TexasRammer
College Station, TX
When your shifting and it dies, is it immediately after starting it up? I know back when I had problems with my tps if I threw it into reverse too fast after starting up it would die.
RompinRam
RompinRam
Hoffman Estates, IL
4.7 Magnum
Haven't cleaned tb. Gonna try it this weekend. Changed plugs about a month ago.
RompinRam
RompinRam
Hoffman Estates, IL
4.7 Magnum
Yeah it's doing that. That's originally why I changed my tps. I find it hard to believe this one went bad already.
RompinRam
RompinRam
Hoffman Estates, IL
4.7 Magnum
No I forgot I can do that. I'll give that a shot this week as well and see what happens.
