Help with tranny
Chase0808
Georgia
2009 1500 Laramie
So the other day I was backing out of the driveway and accidentally bumped the shifter into park while moving. I didn't hear any grinding or noise from the gears but my truck did stall. It's started back up and seems to be fine but should I check anything or be concerned? Btw I have a 2009 Laramie. Not sure which transmission is in it.
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
While not a best practice to do, you should be fine. Just about all modern automatics have a safety interlock override for the situation you mentioned. Usually when it is slammed from either a driving gear into park or reverse, there is a small clatter but that is the safety interlock override preventing/minimizing damage to the gearing.
charonblk07
Calgary, Ab
F1-A forged 349ci
You have the 545rfe and you'll be fine, I've done it a time or two myself and it's not the end of the world, just not something to do all the time.
RamCares
n/a
n/a
If you begin to experience further issues or consistencies with stalling, please let me know. Thanks - Kevin T, Social Connect Team
