HELP!!!!
Nicolas2018
Québec
Hi, my ram15002013 5.7 hemi dont want a run .
He start but dont run, i check de fuse all ok , pressure of gaz is 64~psi each spark plug make fire, i change the position craink sensor but he dont run any more please help me. thx
tron67j
Maryland
Check the compression on each cylinder, you might have a problem there.
Need a lot more info man, doesn't go into gear? If you want help you gonna have to do better then that.
indept
South Jersey
You say it starts but doesn't stay running or it cranks but doesn't start?. If it starts & then stops it may be a bad key. Try your other " spare" key.
N
Nicolas2018
Québec
Ok i find the problem.. it's my injectors he burn all de fuse now i need to check if one of them or is a electric problem
joshhhh
