Hemi tick 2.0
Burla
2010 Hemi Reg Cab 4x4
@Hemi395 found some video's and paper out there that mds actually lubricates the lifters better then when mds is off. I would read the threads in my sig, do a search, read the polls. If it was pushrods, I doubt with mds engaged would stop the tick, so it is possible a lubrication strategy would work. At the center of both strategies is the science of EP additives, in a lower lubrication application it is these additives and base oils that allow you to retain boundary lubrication. redline 5w30 with a rp 20-820 carries about an 80% success rate, lubegard biotech carries about a 50% success rate. Read the threads and view the polls, these forum developed strategies are proven by ram forum over a decade, the science of these additives have shown in many cases they take time and pressure to plate, so even if the tick isnt gone right away it is still possible 500 miles later it will go quiet. My ticks took 500 miles and then it was gone, and been gone now a decade with a couple self inflicted hickups. worth a shot?
Theair98
Theair98
Central Illinois
Thanks for the encouragement. I have about 200 miles on it post Lubeguard. I guess I will try to be patient and wait. Maybe after a couple oil changes, it will subside. Anyone using synthetic 5W-30 Valvoline or other namebrand oil in their MDS hemi? I know Dodge says not to, but....
ThunderMug95
North Prince George, VA
Ive been running 5w30 for 65k+, no issues and a great UOA a month or so ago.
Theair98
Theair98
Central Illinois
Update: 400 plus miles on engine after Lubeguard. Still have a Singer under the hood. (old reference for you younger kids). I got a CEL at idle last weekend, so I cleared it, rest the connector, and it hasn't come back. The problem I am feeling, is a chug at idle and under load. If I am at a light and slightly release brake pressure, the truck will lurch (not roll) forward in a manner that matches the chug I feel at idle. I have NO CEL at W.O.T., so I am baffled. There is definitely something going on. Could the slop in the lifters cause the valves not to open enough to allow this to happen? When it stops snowing, I am going to have to pull plugs. Also wonder if it is shorting out thru the boot. I had to get pretty rough with them when I changed the rocker shafts. Most of them stayed in the head. I dielectric greased them when they went back in. Is there a thing as too much dielectric grease?
Burla
oh yeah you can for sure. It will stop the spark from igniting the fuel. You should only put it below ceramic part of plus and when you plug it only push the plug in once and if you mess it up pull it and clean it. Very possible too much DEG will do a mis fire.
Out of curiousity what lifters did he put in it. Some lifters like Engine Tech lifters have a very poor rep in the hemi
Theair98
Theair98
Central Illinois
I believe they were oem Mopar lifters. It's either number 4 or 6. I have a feeling a short block is in my future. If I lose a second cam, that would be way too much metal thru the internals.
Burla
I'm not saying that is why you are having a mis fire, just that it is for sure possible. GL
