Hemi Tick? Audio included
18GSMRam
FL
As the title asks.... Sounds like a marble in a can...
No codes or any other issues at the moment, 41k miles on a 2018
Audio
wgreggking
rural Arizona
2017 4x4 offroad
Sounds metalic.
Can you pinpoint a side, top, or bottom?
My 6.4 had a couple of times it sounded like that, went away, hemis are noisy.
Burla
2010 Hemi Reg Cab 4x4
delete working with member pm.
18GSMRam
FL
Sounds metalic.
Def driver side and top at valve cover. I had the truck outside to eliminate any echos in the garage and took a 2" pvc pipe a couple feet long and listened to the valve cover on both sides.... driver's side had the noise.
18GSMRam
FL
Figured I'd add some run time/idle hours to this post since it maybe a contributing factor and the truck has low miles and is supposedly built after FCA changed suppliers for the needle bearings.
755 idle
1521 run
41700 miles on a 2018
