Dennis Smith1966
Thanks for any help you can give.
I have a 2015 Ram 1500 quad 4x4 5.7 Hemi.
I have an error code. For High fuel rail voltage. I changed fuel rail sensor, charcoal canister, gas cap and another sensor under the hood and fuel pump. All of which I was told were possible causes. I still have the check engine light.
Absolutely n symptoms of issues other than check engine light.
Last year DODGE said it was my gas cap. That was the 3rd gas cap installed. I can probably dig up error code if needed.
Also the light has been sort of intermittent?? Never flashes. Just sometimes will go out. Stay out a day then back on. Fuel level in tank has no effect
