Hot idle oil PSI, and display temps.
EdGs
FL
Been noticing my oil psi running at 34 -37 at idle when fully warm. When cruising hot it is 55 ish psi.
2015 Ram 1500 SLT QC 2WD, 111,000 miles.
Fresh oil change, PP 5W-20 with lubegard biotek this change.
Anything to be concerned about?
Just removed and belt-sanded my exhaust manifolds for top rear broken studs both sides.
Also, just noticed after sitting since yesterday afternoon, my oil temp started out at 104°, and my tramsmission was at 100°.
Will watch closer the next day or two, always on edge after doing repairs. Cannot afford to have something go out on me.
Thanks.
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
Thanks.
Normal. I don’t think the temp sensors go down any lower than that on your base cluster so again no concerns.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
Looks normal, and also same specs as mine. Well, same temps during summertime! We at -26F degrees actual air temp this morning.
EdGs
EdGs
FL
I thought I saw them lower before. Sucks to get old....lol.
Nick14
Knoxville, TN
Here is a pic of mine last summer. Once snow stops, 190 thermostat, 5w30, Caulk's plug. Nicktemp ram.jpg
BGW656
