How can I upgrade my 6" to 8"
Jblak87
Dilley tx
2011 dodge ram 2500 4x4
Ok so I have 2011 2500 ram with a 6" lift how can I upgrade it to an 8" inch lift with out buying a new kit
reddot
Wolf Point, MT
5.9 cummins
what kit and parts do you have now? SOA is like all I know about suspensions.
TXKID
Houston, TX
longer shocks and coils will most likely be your main parts to look for. I have currently not heard any news about 8" lifts for 4th gens, but I do believe that one member, Captain Mcgillycutty I think is his name, got a custom 8" top gun lift for his power wagon so maybe shoot him a message
reddot
Wolf Point, MT
5.9 cummins
8in is standard for TGC they adjust their 8in to 10in all the time. Id like to know what you have now before saying what you need.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
If you have 6" coils up front, then you can either add a 2" spacer or replace them with 8" coils. Then you need to address the control arms. If you have short arms now, then this would be the time to upgrade to long arms as the short arms are going to seriously limit the amount of travel you have and are going to have your wheels sitting farther back in the wheel well potentially causing rubbing issues. Next up is the rear. If you have a 4" block now, then you are going to need to either get an add-a-leaf or replace the block with a set of progressive leafs. I am not a fan of the 5-6" blocks that some companies are using. That is just asking for trouble. Then you are going to need 2" longer shocks all the way around. And finally, you will more than likely need a transfer case indexing ring. Being honest, in the end, you are better off just selling your kit, and buying a quality 8" kit.
Jblak87
Jblak87
Dilley tx
Yea guys I have a standard 6" bds lift, but like you said Its probably better and cheaper if I buy an 8" lift :( it just sucks I haven't had my kit for 3 months and now I have to save up to getter bigger wheels and lift grrrrr lol Owell thats life lesson learned thanks for the info I really appriciate it
