How do I remove this stuck nut on battery connector?
4xdad
Edmonton Alberta
2015 powerwagon
You would shoot sparks and hot metal all over your engine bay and paint
4xdad
Edmonton Alberta
2015 powerwagon
Good job young man when wrenching try not to take it too seriously. Take your time and think about the problem. Old farts like me all had to learn too. Tip never try to weld on a hydraulic tank ask me how I know lol. There is a reason we have osha now. But nobody but you can keep yourself safe. Don’t do dumb stuff. Want a laugh search shake hands with danger on y YouTube
4xdad
Edmonton Alberta
2015 powerwagon
What truck 2wd 4x4 for a young fella the best one is the one you can afford. Stay away from the big rims thin tires if you’re in an area where you get potholes. The sidewalls of tires is part of the suspension. Your first line of defence against suspension damage
Finally got it! Thank u to everyone that shared ideas, helped, or just made jokes.
If you loosen the nut,and use a screwdriver in the clamp slit,and open up the slit a bit more,you'll be able to push the clamp on the post farther,then tighten the nut,you'll have a better connection . A battery post is tapered so the farther down the post you can get the clamp,the better off you'll usually be.
SugaryClapz
SugaryClapz
WI
Ok, I will do that in the morning.
turkeybird56
Central Texas
Yeah no sparks or flames of any sort. It’ was a joke. Wouldn’t think you would have to point out the totally obvious but….
WELL: That's why there are "warning" stickers on everything. Coff cup: "May be Hot", DUH !!! I hate how they have dumbed down coffee makers now. Even 1 cup Keurig: Friggin Coffee never "hot". I end up putting my cup in Microwave for 52 seconds to get a Hot cup of Coffee. All the byproduct of dumbed down stuff and BS suits over stuff.
REMEMBER: EVERYTHING U read on Internet gotta be right, correct, 100% true. Why if I am joking, I always state with emoji afterward, not wanna get caught up in stuff, just the PC world of 2023, IMHO.......
DA BOIRD
turkeybird56
Central Texas
WaHoo. Give dat man a Cigar, maybe bag of jelly beans (Ronald Reagan).
turkeybird56
Central Texas
TIRES, mine are getting close to bald so I opened a new thread of which tire to get for year round (snow is on the ground right now).
INSTEAD of OPENING up another tire thread, do a lil search/research, there are a Whole bunch of threads with great info available to U in forum.
Sherman Bird
Houston, Texas
Seriously though op those bolts are really pretty soft so you should be able to use a set of vide grips and a socket to just twist it in half. As a heavy equipment operator and an avid 4wheeler I have seen lots of battery’s blow up. That’s one of the reasons an age battery is better but they are spendy. Always disconnect the cables any spark can cause an explosion. Some of the older guys probably picked up on the grinder thing. I am just a smarta$$ old fart trying to be funny.
A.G.M. (Absorbent Glass Mat) batteries have been my friend in instances where I have my truck sit for weeks/ months at a time. In a daily driver, maybe not worth the super high additional cost. Moreover, AGM batteries have their own unique requirement for charge state maintenance, and are not compatible with some OBD2 computer controlled charging systems. This I know from professional experience! Tread carefully!
Marshall
Sk, Canada
2014 sport
I am not going to read all the posts,
But all you have to do to change a battery is loosen the nut a couple of turns and wiggle the terminal a bit ang pull it off
No reason to take the nut off the bolt
Marshall
Sk, Canada
2014 sport
I see people talking about nut crackers
Really, I have never used one in all the yrs I have worked on stuff
A one off job?
Go buy a hack saw and a good quality metal blade, you can use that for lots of stuff
Hard part will be holding the cable while cutting
You should be able to get that nut to thread back down , easy if it was off the truck, a anvel and hammer
RamDiver
Marlborough, Ontario Canada
2021 DS
Rest easy, the OP solved his dilemma... somehow.
acasey
I was trying to replace the battery today when the last step was putting on the battery connectors and the negative connector bolt had a stuck nut on the end that would not come off at all. I was wondering what would be the easiest way to get the nut off of the bolt or remove the bolt and nut and replace them?
Why are you trying to remove the end nut from the post, It's not necessary. Take a screw driver and pry between both ends of the clamp and spread them apart a little to remove the post. Replace the battery and tighten the bold up and your done.
Stephenville newfoundland Canada
2014 outdoorsman
just put a small standard screw driver between the gap and spread the connector alittle
ameer73
