4xdad
- Joined
- Feb 18, 2021
- Posts
- 2,294
- Reaction score
- 2,492
- Location
- Edmonton Alberta
- Ram Year
- 2015 powerwagon
- Engine
- 6.4
You would shoot sparks and hot metal all over your engine bay and paint
TIRES, mine are getting close to bald so I opened a new thread of which tire to get for year round (snow is on the ground right now).Praise the Lord. There's hope.
Congratulations. So what's next?
If you loosen the nut,and use a screwdriver in the clamp slit,and open up the slit a bit more,you'll be able to push the clamp on the post farther,then tighten the nut,you'll have a better connection . A battery post is tapered so the farther down the post you can get the clamp,the better off you'll usually be.Finally got it! Thank u to everyone that shared ideas, helped, or just made jokes.
Ok, I will do that in the morning.If you loosen the nut,and use a screwdriver in the clamp slit,and open up the slit a bit more,you'll be able to push the clamp on the post farther,then tighten the nut,you'll have a better connection . A battery post is tapered so the farther down the post you can get the clamp,the better off you'll usually be.
WELL: That's why there are "warning" stickers on everything. Coff cup: "May be Hot", DUH !!! I hate how they have dumbed down coffee makers now. Even 1 cup Keurig: Friggin Coffee never "hot". I end up putting my cup in Microwave for 52 seconds to get a Hot cup of Coffee. All the byproduct of dumbed down stuff and BS suits over stuff.Yeah no sparks or flames of any sort. It’ was a joke. Wouldn’t think you would have to point out the totally obvious but….
WaHoo. Give dat man a Cigar, maybe bag of jelly beans (Ronald Reagan).Finally got it! Thank u to everyone that shared ideas, helped, or just made jokes.
INSTEAD of OPENING up another tire thread, do a lil search/research, there are a Whole bunch of threads with great info available to U in forum.TIRES, mine are getting close to bald so I opened a new thread of which tire to get for year round (snow is on the ground right now).
A.G.M. (Absorbent Glass Mat) batteries have been my friend in instances where I have my truck sit for weeks/ months at a time. In a daily driver, maybe not worth the super high additional cost. Moreover, AGM batteries have their own unique requirement for charge state maintenance, and are not compatible with some OBD2 computer controlled charging systems. This I know from professional experience! Tread carefully!Seriously though op those bolts are really pretty soft so you should be able to use a set of vide grips and a socket to just twist it in half. As a heavy equipment operator and an avid 4wheeler I have seen lots of battery’s blow up. That’s one of the reasons an age battery is better but they are spendy. Always disconnect the cables any spark can cause an explosion. Some of the older guys probably picked up on the grinder thing. I am just a smarta$$ old fart trying to be funny.
I am not going to read all the posts,
But all you have to do to change a battery is loosen the nut a couple of turns and wiggle the terminal a bit ang pull it off
No reason to take the nut off the bolt
Why are you trying to remove the end nut from the post, It's not necessary. Take a screw driver and pry between both ends of the clamp and spread them apart a little to remove the post. Replace the battery and tighten the bold up and your done.I was trying to replace the battery today when the last step was putting on the battery connectors and the negative connector bolt had a stuck nut on the end that would not come off at all. I was wondering what would be the easiest way to get the nut off of the bolt or remove the bolt and nut and replace them?
just put a small standard screw driver between the gap and spread the connector alittleI was trying to replace the battery today when the last step was putting on the battery connectors and the negative connector bolt had a stuck nut on the end that would not come off at all. I was wondering what would be the easiest way to get the nut off of the bolt or remove the bolt and nut and replace them?
