How hard is it to replace the rear springs?
grizzstang
Calgary, Alberta Canada
I tried searching and the best I could find was a video from Tuff Truck that really doesn't show you much.
It looks like they lifted by the frame and undid the shocks and lowered the rear diff until the springs come right out. Is it really that easy?
12sportmc
NC
Yes. It's super easy. Look in the DIY section for adding a rear spacer. Same concept just swap your spring instead of installing a spacer
WilliamS
Tampa FL
Its really really easy. Your steps are dead on. Lift the rear and put the rear axle on jack stands, removed the tires, unbolted both shocks and have a high lift jack under the tow hitch. Be sure to secure the front tires so it doesn't roll. I was able to pull them both at the same time.
yillbs
If you plan on replacing 'em, you should throw on some riderite airbags too :) It'll help extend the life, make heavy loads a bit easier to manage, and are dirt cheap!
grizzstang
grizzstang
Air bags don't like our climate much. Everyone I know that has put them in has them leak in under two years. I bought some TT-1223V's to help with towing as they will give a 35% capacity increase without changing stock ride height and are designed for trucks that won't be loaded 100% of the time. The reviews look good so I hope they work as they say.
Dbush36
Fort Wayne IN
Everything everybody else said!!!! Took me about 45 min-1hr taking my sweet a$$ time.
yillbs
oh man, sorry to hear that. Can't argue with the springs you got, i've never tried them, down in texas airbags seem to work well though, hope they work out for ya. You should get some sag pictures of after a load with the old springs, and after a load with new springs, i'd be inclined to enjoy seeing that :)
jawzs2
Air Force
South Jersey
Don't think you'll be disappointed, I have the 1223v's on mine. When I hooked up my TT with the stock springs, it would sag about 3 inches, with the 1223's, only about 1 1/2. It also helped with the porpoising on the wonderful roads up and down the east coast
grizzstang
grizzstang
I got the springs in this morning. I used R.L.K's method with the exception of not undoing the sway bar end links. Undoing the brake line brackets on the frame certainly gave the brake lines more slack so they didn't look like they were hanging on them at all. Thanks for the tip R.L.K.
I did get excited and forgot to measure the stock stance before I yanked the old springs out which was not too bright. I have a stance now of 37 1/2" up front and 39 1/2" in the back, so a 2" rake which seems about right. I measure to the ground, center of the wheel, to the bottom edge of the fenders.
My trailer is at a storage lot so I haven't had a chance to hook it up and check the sag yet.
12sportmc
NC
Any pics with the new springs installed?
grizzstang
grizzstang
picture.php
It looks pretty much the same rake as stock.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
yup, 1223v were one of the best upgrades I did to my 1500. felt like it helped unloaded handling as well.
billyw
Northwest
When I switched to 1223v, I also added a 1" spacer. The net result was an increase of about 1/3". The ride is great, but still a little more sag when towing than I was hoping for. I may still augment with bags.
barr0208
winnipeg manitoba
2019 ram 1500 sport long bed
5.7 3.92 4x4 ruby red
1223v springs installed :roflsquared:
