So this afternoon after being released from drill, I decided to install the door handles (or at least the driver side, as that's the more difficult one, and the one I would use most), and tackled the install in my parking area (uncovered) in 35 degree weather. Mostly went well, but I think I have a broken wire for the handle as it doesn't respond at all.
Just so I'm clear: there isn't any "sleep" time needed for the truck to recognize the door handles, correct? Seems that it shouldn't need that: the keyless go was instantly working once I got that installed, so I'm guessing that once the handle is connected, you're good to go on the passive entry too (it's enabled in the BCM already). I tested the handle before I installed it on the truck (and swapped around my wires to ensure I didn't have the color scheme messed up from the C2 connection). I did NOT test the wire/handle for the passenger side yet- but I'm about to go sit in the truck and give that a shot as the wire is still coiled in the kick panel for the passenger side.
The door handle verification test continues to show "Not OK" for all four doors (despite the driver side connection being made), so I hope there is just a cut in the wire around the B-Pillar where I split the tape to run the antenna wire up the pillar. My guess is that's the issue, but I'll test the passenger handle/wire to hopefully rule out the C2 connector.
Do you have access to a multimeter?
Sent from my Nexus 6P using Tapatalk
I’m seeing black as the return on the handle- position 2. https://www.ramforum.com/threads/how-to-add-factory-keyless-enter-n-go.134961/page-5#post-1935320Just to clarify (since I'm obviously screwing something up): the stock wires on the door handles are red and black. I'm seeing this as Red=Return, Black=Sense correct? I'm basing this off the INLINE-DOOR FRONT LEFT/PEM JUMPER connector description diagram that Jimmy07 shared in the beginning of this thread.
The red wire (return) is in Pin 2 (the embossed digit on the back end of the stock connector), and the black wire (sense) is in Pin 1 as the wires come out of the back of the handle. I cut the stock connector off and used Amp MultiLock .40 pins/connectors to recreate the handle's female connector, and the male socket is what I attached to the wiring I ran from the C2 connector. In my case, the red/black pair are arranged the same way the stock connector showed: assuming the release clip is the 'top', then at the rear of the connector, I'm still showing Red in position 2, Black in position 1.
Am I missing something?
Can you fail (unplug )one door antenna at a time and make sure the correct antenna shows the fault just to verify all your antennas are in the correct location ?
That’s where I would start my trouble shooting .
Then once that’s all done then you know for sure it’s the door handle wiring .
Also the passive entry is set on in the radio settings ?
I got nothing. BOTH handles are installed now; but neither work, and the antennas come back as present in AlfaOBD. Still getting the ""Not OK" response when doing the handle verification test. I've also reset/replaced the hub a couple times (though not with both handles installed and connected).
Ugh. Sounds like I'll have to pull the back seat and double-check the C2 connector to ensure I got the door handle pins in the correct slots...and the correct orientation (signal/return colors are as I thought I'd set them). Swapping the bare connector on the ends of the signal wires with the pins on the handle didn't cure anything, so it's either a break or the pins are in incorrect positions on the C2 connector. I'm not going to be happy if there's a break somewhere in the wire, but that wouldn't surprise me since the gauge is so small. At least the handles are ON the truck now. One less "major task" to accomplish in the snow that's heading my way (unless I have to re-run new door handle wires). Sucks not having a garage.
Does anyone know of a de-pinning tool (a paperclip is too large to work IIRC) that I can use to get the pins out of the C2 connector?
Ok so that is a good start .Can you disconnect (fail ) the front Centre antenna ?Passive Entry IS set (checked) in "Settings".
I unplugged the Passenger Passive Entry Antenna (Passive Entry Antenna 2), and once it was disconnected, I got a "B1A72" fault:
Passive Entry Antenna 2After I reconnected the antenna, I cleared the faults and the only ones that remain are the "B25A9" and "B25AA".
Open circuit
Last test failed
Error present
Failure warning lamp 'ON': Not requested.
B25A9:
Front Driver Door Handle Sense
General electrical failure
Last test completed unsuccessfully
Error present
B25AA:
Front Passenger Door Handle Sense
Error present
I thought I had a bad handle and wasted a ton of time checking wires and redoing the pins. It turned out I had the antennas pinned to one location and installed in a different. Double check where you pinned them on the C2 vs where you installed them in the vehicle.
Passive entry needs to be enabled in Alfa and you can also verify on the 8.4 that it is checked in settings / Doors and locks.Just to clarify, this is in the setting in Alfa, not the 8.4 screen.
Passive entry needs to be enabled in Alfa and you can also verify on the 8.4 that it is checked in settings.
I edited my post to reflect where.Hmm it is in Alfa but no where in my radio
