How To: Add Factory Keyless Enter N Go
Ricks Ram
I purchased the handle from AllMoparParts so hopefully it’s my truck being dumb. When I walk up to it. The dash lights up but nothing happens. As far as the unlock.
We've done a few and bought most the the handles and parts from Allmoparparts.com and haven't had any issues. So is it not waking up even when you slide your hand between the handle and the truck?
Lawsuit11
Fort Worth, TX
No. It wakes up about 1/4 of the time but doesn’t unlock. It just goes back to sleep when it does wake up
I’m going to try the battery trick to see if it resets everything and reads everything correctly. I will send an update when I have finished the battery procedure lmao
Ricks Ram
Wow that's kinda strange. I would recommend doing your passenger side handle and then seeing how the truck acts. I know some guys are running the driver's side handle only with no issues but when I re did my wiring and mounted the antennas correctly in my rear doors I noticed that the door handles didn't unlock very well when they only had one side connected. It seemed like it glitched the system a little bit. Maybe that's what you're dealing with now.
Lawsuit11
Fort Worth, TX
It could possibly be the “problem” I always have bad luck. Lol. I will keep everyone updated. Guess I’ll be installing the pass handle sooner than I expected lol. Thanks for your help. This is why I love this forum.
chrisbh17
I'm using drivers handle only. Works OK but for some reason if my fob is next to my phone the truck wont sense it. Thinking it's NFC on my phone but also wondering if it's because I have the antenna in my b pillar instead of the rear door.
I'm sure I'm still getting faults from the passenger door handle missing but the system still works OK.
Ordered my handle from Benny... Figured a used handle would just introduce more variables.
Sent from my Nexus 6P using Tapatalk
Lawsuit11
Fort Worth, TX
Yeah that’s the same thing I figured. I found a set of used handles black and chrome that match my truck for under half the price but I didn’t want the headache if there was something wrong with it
Lawsuit11
Fort Worth, TX
After a battery hard reboot. Disconnecting battery cables touching them together and letting it sit for 15 minutes. Everything seems to be functioning properly. I let the truck sit for 15 minutes after I locked it. And hooked the battery back up. Walked out and it unlocked first try. I’m still going to install the pass handle this weekend just to make sure.
icetraxx
Looks like the in cab antennas 56046958AA are on back order everywhere(unless someone knows where they have them instock) Would the door antennas PN# 56046957AA work in their place? Has anyone tried?
Ricks Ram
Yip. We have been waiting for over a month on our order. Just talked to Benny and he said we are still most likely at least 2 weeks out probably closer to 3. Not sure if the door antennas would work in the cab or not but if I had to guess I would say it's definitely a possibility.
Lawsuit11
Fort Worth, TX
When did you put the order in? I must have just made it cause I placed my order on 06/05/2019 and they shipped it 06/14/2019.
Ricks Ram
06/06/19
Ricks Ram
I beat you by one day. Man that’s rough I must have got the last few or somewhere close.
Just went back and double checked and it was 06/11/19. I thought it was on 06/06/19. I was off a couple of days. Definitely been a long time either way . We have the harness made and ready to go for my buddy's Bighorn.
Lawsuit11
Fort Worth, TX
That’s the hardest part in my opinion is waiting for the damn parts
Ricks Ram
Yip I agree. The waiting sucks. His truck is a 2019 Classic so I'm exited to see how it all works. It will be the first 2019 we have done.
icetraxx
What wire or wire cover are yall using? I've seen some with the just the wires and some with a black cover over the wires. I like the look and protection of the wire with the cover.
Ghost_RAM
VA
@STecoD Used a shielded cable if I'm not mistaken. I used the twisted pair linked in the OP then used a braided sleeve to cover the wires.
Ricks Ram
STecoD and I both also use the Tesa 51618 19mm X 25m cloth harness tape. It's pretty much identical to the factory harness tape. There are a lot of knockoffs out there but the Tesa brand seems to be the best we have found. We did also use shielded wire for the push button start but wrapped most of it with Tesa tape as well.
skuppy069
canada alberta
2018 1500 cc
I might have a antenna or two kicking around .
I can take a look on Sunday when I’m back home .
nmckean
Grand Rapids, MI
Anyone have a line on the passive entry antenna 56046958AA.. Apparently there's a national back order until November
Joey93
