How To Add rear Park assist
SRich2015
USA
Great job @skuppy069 yes that’s a lot of crimping and stuff!! I think as far as the rear goes if one has the plug already there then coming off the I220 plug is the way to go. That and buying a module with the C1,C2 and C3 pigtails attached will save a lot.
NovaScotia Ram
Gananoque, ON Canada
View attachment 208780 I sent this to another member to try out . It’s a first go so will see when its installed if there are any suggestions for improvement etc .
It’s about 150 Canadian in parts roughy and about 8 hours of work .
I really hope someone picks up building these harnesses. They look really good. Well done.
Since we're both in Canada, where did you order your parts?
jjtessmer
I will pm you later this afternoon
Hey sorry for the late reply. If you do post up a diagram let me know. I have a 2017 donor laramie at work I could cut everything out of (pig tails) to make my own harness.
GWR Ram
Middleton, Idaho
6.7 Diesel
Why cut the pig tail connectors only? Why make your own harness? You have everything there from what you are saying. You might have to add some wire here or there but yours would be a whole lot easier then other guys here.
Michael Trevisan
Middletown CT
Does anyone have the pin out for the 6 pin? I did not have the plug in the back and had to run my own cable from the front to the back just don't know how to hook it up
SRich2015
USA
Cesar592
3.6 pentastar
hey how are i have these two connectors to which i have to connect for the signal of can c.
Cesar592
3.6 pentastar
but that one is busy I can disconnect one
Jimmy07
No. Are you sure you don’t already have the park sense module connector present already, since you’re block is fully populated? If not, you’ll have to use the can c block that’s over on the passenger side dash.
Cesar592
3.6 pentastar
I need to check again but I did not see any connector for there
Jimmy07
It’s calling for yellow and violet wires on that connector. That one “appears” to be blue, but could be the picture, and there’s nothing else it’s showing that connector to be for.
S
skuppy069
canada alberta
2018 1500 cc
The one above that is c13 for air suspension .
Yellow/yellow with grey
Cesar592
3.6 pentastar
here is another photo better taken
Lowrider357
