Let me preface this by saying all trucks are different. Some have the harness installed all the way to the BCM while many don't. (SOME HAVE THE CONNECTOR AND IT NEVER COMPLETES THE CIRCUIT. You need to tone all the way through to ensure. If it does not make it all the way through it is almost impossible to find where it stops as the harness is wrapped pretty tight.
68159725AB (1500) Hood latch with switch
68065018AA (1500) Repair Kit with connector
https://www.mouser.com/Product...29-13627884-L?r=829-13627884-L (BCM PIN)
18 gauge primary wire from autozone
Grounding terminal from autozone
Heat Shrink
Amazon or Ebay
Replacement tip start overlays (4 Button)
OR
Replacement Keyfobs (4 Button)
The above cost around $60.00
A kit from MOPAR cost about $230 to $320
Programming from the dealer ranges $80.00 to $120.00 in my area
The following can be used for other installs
Crimper for BCM terminal
The following can be used to program and forego dealer programming. (DEPENDS ON LEVEL OF ABILITY AND COMFORT LEVEL)
MX ODB Adapter (for programming) $70.00
Amazon
ALPHA Software (for programming) $50.00
Google Play Store / Windows Store (require android or windows device)
Instructions.
https://www.mopar.com/moparsvc/pim/media?id=9012385939486
Hope this helps
Joe
