BeardedContractor
SE VA
CTD
Installed a UAQ and media hub from infotainment.com in my 2016 2500 CTD. Everything is working fine except the soft keys for heated seats and steering wheel. After a couple of hours on this thread reading every post I could about people with similar issues, what is the fix? From my understanding it can be fixed with a BCM setting using an AlfaOBD? I don't have the hard keys for this function.
ajairola
Houston
Did SXM show up on the radio? The "controls" and Satellite radio will be some of the last things to show up, and may take a few drive/rest cycles.
BeardedContractor
SE VA
CTD
Yes everything else has shown up. This is second radio I got under RMA. Have tried resets and waiting over a week for it to work with no luck. The controls are there just greyed out and the seats will auto on but can't control or turn on passenger.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Have you asked infotainment?
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
What did Infotainment.com have to say the problem / solution might be? What was the problem with the first radio, same thing or something different?
BeardedContractor
SE VA
CTD
Same problem, they wouldn't say anything other than they think something was wrong with the previous unit and sent a new one.
Roman217
Metro Detroit, MI
Whats the part number of your heated seat module? It will in the front left corner under the driver's seat.
Sent from my SM-N986U using Tapatalk
BeardedContractor
SE VA
CTD
P/N: 68217268AD. The heated seats work fine with my factory radio, they even come on when temp is low on UAQ. Soft buttons show that they are on with UAQ radio but there is no control. The buttons are greyed out.
autumnwalker
Canada
My HU arrived! Missing Fakra B (FM) - trying to find a pigtail that isn't going to take several months to arrive. Do I even need it? Could I just plug the antenna wire into the back of what's left (the metal barrel on PCB)?
Radio has part number 68340153AD. It's a Canadian UAQ from what I understand. Panasonic stickers with VP4R-A. Blue sticker on top (firmware?) is 18.11.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Which Fakra is missing?
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Yes, you can, but you should get a Pigtail extension to take the stress off the connector as soon as possible. See Post 10 in the 8.4 upgrade thread for fakra Pigtail links you can use.
Side note:
Do you know the year and vin of the Canadian ram truck that UCQ PN came from?
M² Mods.
autumnwalker
Canada
Those are the ones I'm looking at ... ETA is March :(
I do have both - do you want me to post here or DM? Truck was a 2018.
Is there any reason I cannot "break" the fakra on my original 8.4 and glue it onto the back of the new 8.4? Similarly (and likely not as stupid of an idea) could I get a replacement fakra (like this Fakra Plug male End Launch PCB mount Right angle connector white/9001 New | eBay), disassemble and glue the plastic / barrel onto the 8.4?
autumnwalker
Canada
I'm also seeing a Fakra Z plug - which appears to be universal (all Fakra plug into it). I cannot find a white pigtail that will ship in a reasonable timeframe, but I can get a universal "Z" in a couple of days. Has anyone looked into that option?
autumnwalker
Canada
bloup
I would pull the white connector off the old radio and glue it to the new one. I’ve done it myself.
autumnwalker
Canada
This is going to sound real silly ... but how do you pull it off (without breaking it) and what did you use to glue it on?
bloup
One of the little tabs will break, I haven’t found a way to remove it with damaging it a bit, I used gorilla glue on the square flat section.
Roman217
Metro Detroit, MI
I will check the software revision of the 68217268AA module I tried with my UAQ. Now I am wondering if only the newest revisions work with both radios.
BeardedContractor
SE VA
CTD
Awesome, thanks. I have a OBD2 module coming for AlphaOBD so I can poke around in there and see if anything that looks out of wack. Infotainment finally got back to me again after I elevated the issue and they said they have never seen this issue before and have no solution. They offered a $75 refund. I did ask if the module for the older trucks would do anything or they would be willing to ship me one to try. My truck is a MY 16 but has a production date of August 2015 so maybe they used a BCM or some other part from previous years that is causing the issue.
