- Nov 15, 2016
- 1,026
- 833
- Location
- Central Virginia
- 2011 1500 Laramie CC
- 5.7L
My TYC fan was delivered yesterday. Will be done before end of weekend...sooner if the weather cooperates!
Yes, I just did this on my 17 express the other day.
What's involved? The fan only has 2 wires going to it? Does it run slow speed when stopped and go high when it gets hot? Did you swap the tstat out too?
Does it stay around the right temp? Do you have a tune?
Has there been a way to figure out how to fix this write-up and its images????
If anyone has the original images I can try to rehost through tapatalk maybe?
That's an impressive fan, what model is it?
I know that the v6 fan with tuner to control the temp that it kicks on seems to be the top choice for this mod. Is there any way to use the v6 fan (either OEM or aftermarket like TYC, etc) and wire in a separate controller to adjust when it turns on and off? Seems like a potential way to save money for those of us (like me) who do not have a tuner yet. Although...then you do lose some of the convenience of plug and play.
Yes definitely! Even though I have a tuner on the way I may still invest in something like this. The 2013+ only has a ON/OFF fan function and no HI/Lo fan capability.
If I add a unit like this I will be able to tune it to kick in hi/lo and it has a temperature probe that attaches to the rad to determine when to kick the fan on. Here is a 2-speed unit but there are many out there.
https://www.summitracing.com/int/pa...oogle-_-shopping-_-srese1-_-hayden-automotive
Do you think you'd be able to wire the controller into the factory efan harness? Or would you basically take the connector off of the fan and truck and just hard wire it directly in?
