I thought the same thing.....so I ordered a new unit. I'll post results.
Possibly, but it may be a bad HVAC module. Dealer trip is in orderI have an ‘18 with the manual climate control and seven speed fan. Mine temperature slider is out of sync. It used to be right. When set to hot, it is hot, but when set to cold it is warm unless I keep pressing the temp down button. I have had two recalls done but I am told they wouldn’t have anything to do with this. I have had the Uconnect update as well, I wonder if it may be to blame?
The one that came with my truck. I didn’t change it out. That said, I only felt for hot air and it was pretty hot. I didn’t pull the glovebox to look. Based on the description of the prob though I would have expected warm air, not hot. I’ll know on the first cold morning for sure but as of right now I don’t think I’m seeing the issue.
Not sure I understand your questionI have a question related to the temperature control issues some of us are having. The manual temp control is not working right but what about the trucks with this issue that are auto climate control capable? Do they work correctly when in auto mode?
Application version 19.9 is the same version on both my UAx Radios and it worked well in my 13 ram & factory 18 UAS truck. What's the PN on your radio again?
M² Mods.
2015 1500 Express Crew. Originally an RA1, upgraded to an RA2 on my own, then decided to take the easy / safe routo and went with an Infotainment kit for the UAQ upgrade.
