Index the clock spring
bellaireroad
Fort Worth
Getting ready to swap my wheel. I’ve actually pulled the airbag before, so very familiar with that process. I also have a set of puller’s, so no problem there.
Only thing I am concerned about his indexing the clock spring. I have noticed that the new clock Springs come with a plastic tab, that you pull after installation. Would it be a good idea to place a piece of plastic or a dowel in there before the wheel is actually pulled? Or is this really that big of a deal?
Also anyone know the torque spec on the wheel nut?
misfit77
I used tape. Wish i could find the YouTube video i used.
Sent from my moto g power using Tapatalk
misfit77
After.. it's nit spring loaded. Its a cartridge of some sorts.
Ive done wheels on a miata, ram and cr-v. Not an issue.
misfit77
The tape just holds it in place while u fidget around.
bellaireroad
bellaireroad
Fort Worth
Ahh, ok. I was concerned about it moving while the wheel is being pulled
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
It's more of an issue of it moving after it's pulled but before you re-install it. This should help...
bellaireroad
bellaireroad
Fort Worth
Thanks to all. Got this done today with no problem
