infamous hemi tick
josuha
prescott
my 2006 1500 ticks at startup and stays constant through being warm and when driving. I've read that it could be the lifters or an exhaust leak. im pretty sure this question has been asked a thousand times but any help would be really appreciated.
donovanp97
New York
To answer that I have a 5.7 Hemi 2008 and on a cold start until I drive to my next destination it ticks, it’s called the hemi tick because something of how the engine was manufactured would cause a ticking sound. I thought it was bad when I first noticed it but I asked the same question and got a response saying it was normal
J
josuha
prescott
so the tick is nothing to be concerned about?
donovanp97
New York
Does it go After you drive it somewhere else ?
LeesEvoX
Houston, TX
Hemi 6.4l
If the tick doesn't go away once you reach operating temp you have broke. Exhaust bolts.
If the tick does go away once you reach operating temp. The probably lifters, as the noise will be less pronounced when warm due to everything taking some time to get a nice oil film going
Spoonsize
Myrtle Beach, SC
Hydraulic lifters, when going bad, will tick until oil pressure keeps them pressurized. Once bad, the push rod will often break thru. If the tic goes away within 10 to 15 seconds.....lifter.
PLEASE, correct me if wrong about this. Thanks.
J
josuha
prescott
@donovanp97 no its constant ticking just not as bad when up to temp. @LeesEvoX I hope the exhaust bolts aren't broke I don't really wanna spend a weekend trying to get them out.
Max1329
5.7 Magnum hemi
Run redline oil and the tick will go away
donovanp97
New York
Broke exhaust bolts are an easy fix, get an extractor set and new bolts. Gasket
Fast69Mopar
If you do have any broken exhaust manifold bolts, it will not take a weekend to extract them. It is a pretty simple process with the right tools and equipment. If you do find one or more are broken, take your time and do the repair right and you will be fine.
BoBoway4
