Install of oem tow hooks on a 14 Express
Kentucky
Powertech 4.7
Oh damn didn't even see that, thanks! Did you ever find your brackets? I have the ones from the set I got off Amazon. They are the enixwell ones. I got the custom brackets so no use for them, but they aren't both the same, they messed up and sent out mirrored versions. It could still work you would just need to cut the ear off the passenger side one. I could send em to ya if you wanted no charge
Sure I'll take them because I was going to use the brackets from a 3 gen Dakota that would've worked but everywhere I order them I received oh sorry turns out we're out of stock.
So I'll pm you my info.
FLYxxBOY
Ohio
Got my hooks in! The brackets are awesome and make the hooks sit much better than the stock ones. Also thanks to @JB1 for his trim idea, cleans it up very well
Badger 13
North Idaho
2013 Dodge Ram 1500
FLYxxBOY, very clean looking install. Did you remove the plastic piece for cutting, or cut it in place ?
FLYxxBOY
Ohio
Thank ya, took a while but I think it turned out good. So the method I used was to take the plastic piece out, installed the hooks, used some painters tape and taped around the hooks so I knew where to cut, removed the hooks, put the plastic piece back in, then using the tape as my outline used a 1 1/4 hole saw to drill the ends, and a hobby knife to cut between them. Then added the trim stuff to make it look neat and installed the hooks again.
Badger 13
North Idaho
2013 Dodge Ram 1500
Thanks FLYxxBOY, it did come out very clean, and gives the look of a "factory option". I was looking at removing the plastic piece, but it looks like a PIA to remove, and reinstall. If I want to achieve the good look of yours, I guess I better figure out out to take that piece out.
Thanks again.
Jim
Uncle Damo
Where to get the brackets for a Sport these days ? I've read through hundreds of posts, and saw that @Deepjeep85 was selling them last year, but haven't seen activity from him since or a response to my inquiry. The hooks are easy to find, but need advise on where to get brackets if anyone can help. TIA
Uncle Damo
Thanks to @Ken226 I was able to grab his pdf files, scale them on the printer, and use them as a template to create my own brackets which worked out perfectly. It took $50 worth of carbide blades and at least 4 hours of my time to work the 3/16" angle iron with saws and a drill press, but in the end turned out exactly as I had hoped. Used OEM hooks from ebay which I sand blasted and repainted. Thanks to everyone on this thread for paving the path !
tmCjCxDanaEk8bVG7
18GSMRam
FL
What exactly do the brackets do for you? I didn't read the thread
Uncle Damo
the brackets allow you to position the hooks wider and aligned with the larger opening in the fascia, as well as face them outwards. You could use the OEM brackets without those two benefits.
16WhiteQC
Hudson valley, NY
Forgot to update this thread with my install.
All info in it, bracket dimensions and cleanest lower valance cut outs you'll find.
ulemon
Iowa
Hey I called up my local metal fabricator and he was wanting a '.dxf' file format since that is what his cad software used, does anyone know if there exists a '.dxf' version? Or if anyone is still selling them?
Sasquatchtdg
Moncks Corner, SC
Is there a specific part# or part revision of these tow hooks that have a better/beefier build to them?
kad
Hudson Valley, NY
5.7L HEMI
As far as I know there are only 2 versions of 4th Gen 1500 tow hooks, the standard ones from 99% of the trucks and the ones from the Rebel, which IIRC, are closed loop rather than hook. The ones from the HD trucks are completely different and don't mount to the 1500.
-K
TMFMK
