Installed new DDM Canbus HID kit
Dirtbikekid1998
Maine
2015 1500 Laramie Brilliant Black Crystal Pearl Coat
Just got my plus canbus kit for my fogs after returning the cheaper kit. It works! I used same kit as my lows ddm plus canbus 35w-9006 4500k 92da308dcec36ed63fbbd60c41afaaf6.jpgf1033d7ddac9d74a11a328858dd54318.jpg7050417975f888c9bde8d2759be2016f.jpg
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
Could you tell me part numbers and where you ordered for your projectors and fogs?
Dirtbikekid1998
Maine
Go to ddm tuning .com. It's the plus canbus kit.d80bd28d0d94a0be9f6cd937ab519645.jpg94eb171634e4b64e7fdf3c0c876406b0.jpg
Joshwaa
Lake Worth, FL
Thanks for that. Do you have any pics of your installation?
Dirtbikekid1998
Maine
Where did you end up mounting everything for your fogs?
Sent from my SM-G900W8 using Tapatalk
Sorry i didn't take pics when I did it and my truck is at the dealer putting a factory trailer brake on it because myn didn't come with it. so i will try to get some when it comes back later today. I mounted my ballasts on a angular plastic piece that connects to the fog light housing. I just took some self taping screws and bolted the ballast to that angular piece. All that plastic piece was was a brace so it did not hert it to drill into it.
TRXHemi
Sugar Land, TX
FWIW, on my 2014 for the fogs, I used a CANBUS kit with zero issues. Initially I installed a regular hid kit for fogs. All it did was flicker. So CANBUS ballasts FTW!!
Dirtbikekid1998
Maine
Hey I'm confused. I though that fogs where h10. Are they 9006?
Myn are 9006 I think previous Rams used h10.
noupf
NY
2015 CC Sport 6'4 Bed
just curious if you know......were the bulbs that you took out of the stock projectors the same bulbs that are used in the fogs? I'm curious if the the stock halogens in the projector are better than the stock bulbs in the fogs.
I am going to get the ddm canbus hid's for my 2015 as well, but id be happy with an upgraded bulb in the fogs.....
Dirtbikekid1998
Maine
The lows use a 9012. It will fit in a 9006 but it needs to be trimmed. I think I remember reading that a 9012 halogen was brighter than a 9006 bulb but I'm not 100% sure.
SportyJames
Corpus Christi
2015 RAM 1500 Sport
DDM packages their bulbs with two white o rings on the bulb end. Make sure to remove these before installing the bulb. I missed them and had to fish them out of the headlight assembly. Rookie mistake on my part, but if you're not looking for them they are easy to miss.
Sent from my SM-G900V using Tapatalk
Skipper
Cary Nc
Parking light bulb!
I couldn't figure out how to start a new thread but I have a question! I have a 03 Ram 1500 . I had a passenger side parking light and license plate light out. I replaced the front bulb but it still wouldn't burn. I replaced the #32 fuse and pow, the plate light works on that side but the front parking light is still out. The turn signal works but not the parking light. It's a head scratcher !
Dmopar74
Has anybody used the canbus kit on a 2016? I have the regular kit from my old car in the fogs now and they work just fine
zstampe
This should be the kit I need for a 2015 with quads correct? I shouldn't need to order anything else? Thanks in advance
Glowz
