Installed RC 3” level/lift - now bouncing at 45 mph
mwardncsu
NC
just finally finished the install of a RC 3” suspension Level/lift (new springs / shocks on front, new shocks and block on rear) on a 2004 RAM 1500 single cab, 6.5’ bed with RWD.
Had Cooper Discoverer XLT 285/75R17 tires installed (previous were 265/70R17) on existing wheels and a alignment performed.
The truck seems to pull a bit to the left so I’ll need them to relook at the alignment - but at 45 mpg there is a pronounced bounce which I believe is coming from the rear. Below 45 it seems ok and once I get over 50 mph it settles out again (haven’t gotten it above 55 yet).
I’ve seen some reference that perhaps the tires may be a little over inflated, or others have described something similar at 45 mph and said new shocks solved it - but I’ve got new shocks
Anyone experience anything like this and have suggestions?
Jason G Slabaugh
Rossville Indiana
5.7l hemi
Wheel balance, possible a wheel weight came off, check lug nut torque as well. That’s where I’d start
M
mwardncsu
NC
seems that it was the wheel balance..... weights were put on the wheel but apparently the surface was not prepped/cleaned properly and some came off - interestingly the out of balance wheel was on the passenger front, but the bounce sure seemed to come from the back - but after taking it back to the tire shop and they re balanced it, all seems OK
