Is it worth it?
yrraljguthrie
Sulphur, Oklahoma
etorque5.7
I recently filled a half-empty tank with 89 octane. 87 was in it. Both had ethanol. With that mix, I've noticed at least a .6 mpg increase. Or course that's only on the one fill-up, but it coincides closely with previous instances with my previous F-150. The fill was at the same pump and I'm driving the same roads. This will pay for about 1/2 of the increase in the price of the 89 vs. 87 octane. I intend to try to use this fill-up and then see what mostly 89 octane by itself will do. Has anyone else noticed an increase in mpg using 89 octane or perhaps 87 or 89 without ethanol? I'm beginning to think using 89 octane will increase the mpg enough to pay the difference in price.
SniperDroid
Eaton Township, Ohio
89 octane 8.4 measured. 92 octane 9.7 measured. Be advised, I choose the higher octane, not required for performance.
Y
yrraljguthrie
Sulphur, Oklahoma
etorque5.7
You must have a lead foot! That's a 15% increase I think, so significant. Unless I've done the math wrong that would make $3.50 gasoline the same per mile as $3.00 87 octane. I may try that. Have to see what the 92 costs.
mtofell
There's some payback calculation on 89 v. 87 octane and I can't remember exactly what it is. I'm thinking it's around 15 cents. Basically, if you have to pay more than 15 cents it's not worth it. Years ago there was a long thread about this and some chemical/fuel engineer had it all calculated out. Of course, this is all predicated on the fact that the engine is tuned/capable of using the higher octane which I believe these modern Rams are.
I had a longstanding argument with my dad about this. He swore up and down that putting 92 octane gas into his 1991 Toyota Camry was why the car lasted to nearly 300K miles. That engine wouldn't know the difference in the octane and he was ******* away my inheritance :) :) It lasted to 300K miles because it was a Toyota.
Once a year I camp out in the sticks and the only gas available is ethanol-free 92 and my truck LOVES that stuff. I'm thinking I get 5-10% better mileage but that's because it has no ethanol.
The same engineer I cited above laughed about the whole ethanol in fuel thing and said after years in the industry the only reason he could figure we put 10% ethanol in the fuel is to keep the corn farmers in business. It causes autos to get 10% worse fuel mileage so it's kind of a wash.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
For me the difference was negligible. 89 octane is 20 cents per gallon more than 87 where I fill up. I'm less concerned about fuel economy though than using what's recommended in the owner's manual so I go with 89.
Dave Haddon
Saskatoon SK. Canada
Just did a trip from Saskatoon to Seattle. Warlock was loaded 3 dogs 2 humans and a full bed with mmm..600lbs of gear. Mostly cruise control 118km/hr..full fill on 89 and range was an incredible 1120. … when using 87.. range was 970…about even value overall on a long trip re diff in gas price but good for the hemi
Mb7640
Fountian hills az
I normally use 89 someone said to try 91 and i may see a increase in mpg so far nothing its the same but giving it a few more weeks. I get 16.5. I have never used 87 in a 5.7l i have had a bunch of them mostly challengers.
TestPilot57
Northern Hemisphere
none
Godzilla 7.3
I generally get 91 just because it's the only thing I can get around here that's E0. I don't get it for increased mileage, but for the health of everything the fuel touches. If E0 is not available I generally get 89 as I feel (no justification) it just must be a bit better than the "bottom of the barrel" stuff...
Big Blue Hemi
Keep on keeping on
Right Coast
2012 Ram 1500 Laramie
I have always gone with 89 in order for the truck to perform properly. I personally think 91-92 is for performance driven and tow vehicles only.
I can say that the ethanol mix crap causes a significant drop in mpg; 12.9-13.1 vs 15.9-16.2. How the hell is that conserving fuel!
Y
yrraljguthrie
Sulphur, Oklahoma
etorque5.7
"I grab the pump handle for the cheapest they have. Always have, always will."
What if the difference in mpg is enough to make the 89 cheaper than 87?
Tulecreeper
Don't usually keep much track of my MPG. Don't care what it is, for the most part. But how much better could it be...1 MPG...2? That's not enough to change anything.
Ratman6161
Buffalo, MN
I don't care much either. I do notice that this discussion usually comes up with 5.7 owners rather than us 6.4 folks. Just for grins though, I have tried a variety of different fuels with octane ratings from 87 to 91 and ethanol contents from 0 to 15%. No difference that I am able to detect. I'm mostly using my truck to tow a travel trailer and I've concluded that how much of a head wind I've got seems to matter more than anything else.
BadHemi2014
Greater Cincinnati area
Mine's tuned for 89 so that's what I use. Over the years I have hand calculated MPG for 5 to 10 tanks of different octane fuels for a few different vehicles including my Ram, and I've never seen a difference.
Y
yrraljguthrie
Sulphur, Oklahoma
etorque5.7
Well if I'm going to grab the handle of the cheapest gas, I want to know if it is really cheaper. If a filling station on my side of the road is 3.059 and across the road it is 3.049 I'll cross the road. If for no other reason than to reward the station with the cheapest. Pennies take care of dollars and dollars take care of hundreds.
Jane S
Do the math on the gas price and mpg improvement. I doubt you will save money.
