- Joined
- Jun 22, 2017
- Posts
- 589
- Reaction score
- 254
- Location
- Western, Idaho
- Ram Year
- 2013 Sport
- Engine
- HEMI 5.7
I have been looking into buying a torque wrench and wanted to know if I needed up to 150 or 250 pounds, well going to go with the 250 because it is 13 bucks more , whatever. Are the below measurements accurate? I compared the Lug Nuts bit and it seems to be accurate. Just curious.
The Wrench I Picked:
https://www.amazon.com/gp/product/B00C5ZL1NS/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
Engine Torque Specs
(4th Gen RAM)
Air fuel control banjo screw (in pump)-----------------------------------------------------9 ft lbs
Air fuel control fitting ( in head)------------------------------------------------------------6 ft lbs
Alternator ground cable mounting to bloc-----------------------------------------------18 ft lbs
Alternator mounting to water pump inlet------------------------------------------------30 ft lbs
Alternator pulley---------------------------------------------------------------------------60 ft lbs
Alternator support (upper)----------------------------------------------------------------18 ft lbs
Battery cable ( negative) mounting to block---------------------------------------------57 ft lbs
Belt tensioner mounting-------------------------------------------------------------------32 ft lbs
Block heater mounting-----------------------------------------------------------------------9ft lbs
Cab heater hose clamp--------------------------------------------------------------------35 in lbs
Cab heater tubing clamp mounting-------------------------------------------------------18 ft lbs
Camshaft thrust plate---------------------------------------------------------------------18 ft lbs
Clutch cover mounting to flywheel--------------------------------------------------------17 ft lbs
Connecting rod (alternately tighten in 3 steps)
Step 1--------------------------------------------------------------------------------------26 ft lbs
Step 2--------------------------------------------------------------------------------------51 ft lbs
Step 3--------------------------------------------------------------------------------------73 ft lbs
Cooling fan mounting to fan clutch-------------------------------------------------------15 ft lbs
Crossover clamp (air)---------------------------------------------------------------------44 in lbs
Cylinder head mounting bolts
1- All bolts---------------------------------------------------------------------------------66 ft lbs
2- long bolts-------------------------------------------------------------------------------89 ft lbs
3- tighten all bolts--------------------------------------------------------- additional 90 degrees
Exhaust manifold--------------------------------------------------------------------------32 ft lbs
Exhaust outlet pipe-v band clamp--------------------------------------------------------72 in lbs
Exhaust pipe clamp mounting-------------------------------------------------------------20 ft lbs
Exhaust pipe steady rest mounting to trans---------------------------------------------50 ft lbs
Fan clutch mounting / fan hub (left hand threads)--------------------------------------42 ft lbs
Fan hub bracket mounting----------------------------------------------------------------18 ft lbs
Fan hub bearing retaining cap screw-----------------------------------------------------57 ft lbs
Fan pulley to fan hub-----------------------------------------------------------------------7 ft lbs
Fan pulley crankshaft-----------------------------------------------------------------------7 ft lbs
Fan shroud mounting nuts----------------------------------------------------------------95 in lbs
Flywheel bolts----------------------------------------------------------------------------101 ft lbs
Flywheel housing adapter-----------------------------------------------------------------44 ft lbs
Front engine mount isolator mounting to mount----------------------------------------80 ft lbs
Front engine mount through bolt---------------------------------------------------------30 ft lbs
Front engine mount to block--------------------------------------------------------------44 ft lbs
Front oil filler pipe-access cover-----------------------------------------------------hand tighten
Fuel banjo screw (in fuel pump)----------------------------------------------------------24 ft lbs
Fuel banjo screw (in head)----------------------------------------------------------------18 ft lbs
Fuel banjo screw (in injector)--------------------------------------------------------------6 ft lbs
Fuel filter--------------------------------------------------------------------half turn after contact
Fuel heater assembly mounting-----------------------------------------------------------24 ft lbs
Fuel heater ground mounting to intake manifold------------------------------------------9 ft lbs
Fuel link fitting (high pressure)-----------------------------------------------------------18 ft lbs
Fuel low pressure supple------------------------------------------------------------------18 ft lbs
Fuel pump drive gear (with pump unlocked)---------------------------------------------48 ft lbs
Fuel pump lock (bosch)-------------------------------------------------------------------22 ft lbs
Fuel pump mounting mount---------------------------------------------------------------18 ft lbs
Fuel pump solenoid------------------------------------------------------------------------32 ft lbs
Fuel pump support bracket----------------------------------------------------------------18 ft lbs
Fuel pump unlock (bosch)-----------------------------------------------------------------10 ft lbs
Fuel vent screw (in banjo)------------------------------------------------------------------6 ft lbs
Gear cover---------------------------------------------------------------------------------18 ft lbs
Gear housing - to - block------------------------------------------------------------------18 ft lbs
Injector retaining nuts---------------------------------------------------------------------44 ft lbs
Intake manifold cover---------------------------------------------------------------------18 ft lbs
Intercooler attaching bolts----------------------------------------------------------------17 in lbs
Intercooler duct clamp nuts--------------------------------------------------------------72 in lbs
Lift pump mounting------------------------------------------------------------------------18 ft lbs
Lifting bracket (rear)----------------------------------------------------------------------57 ft lbs
Main bearing cap bolts
Step 1--------------------------------------------------------------------------------------45 ft lbs
Step 2--------------------------------------------------------------------------------------88 ft lbs
Step 3-------------------------------------------------------------------------------------129 ft lbs
Engine Torque Specs
(4th Gen RAM)
