Is this accurate? Torque Specs
Craw
Western, Idaho
2013 Sport
HEMI 5.7
I have been looking into buying a torque wrench and wanted to know if I needed up to 150 or 250 pounds, well going to go with the 250 because it is 13 bucks more , whatever. Are the below measurements accurate? I compared the Lug Nuts bit and it seems to be accurate. Just curious.
The Wrench I Picked:
https://www.amazon.com/gp/product/B00C5ZL1NS/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
Engine Torque Specs
(4th Gen RAM)
Air fuel control banjo screw (in pump)-----------------------------------------------------9 ft lbs
Air fuel control fitting ( in head)------------------------------------------------------------6 ft lbs
Alternator ground cable mounting to bloc-----------------------------------------------18 ft lbs
Alternator mounting to water pump inlet------------------------------------------------30 ft lbs
Alternator pulley---------------------------------------------------------------------------60 ft lbs
Alternator support (upper)----------------------------------------------------------------18 ft lbs
Battery cable ( negative) mounting to block---------------------------------------------57 ft lbs
Belt tensioner mounting-------------------------------------------------------------------32 ft lbs
Block heater mounting-----------------------------------------------------------------------9ft lbs
Cab heater hose clamp--------------------------------------------------------------------35 in lbs
Cab heater tubing clamp mounting-------------------------------------------------------18 ft lbs
Camshaft thrust plate---------------------------------------------------------------------18 ft lbs
Clutch cover mounting to flywheel--------------------------------------------------------17 ft lbs
Connecting rod (alternately tighten in 3 steps)
Step 1--------------------------------------------------------------------------------------26 ft lbs
Step 2--------------------------------------------------------------------------------------51 ft lbs
Step 3--------------------------------------------------------------------------------------73 ft lbs
Cooling fan mounting to fan clutch-------------------------------------------------------15 ft lbs
Crossover clamp (air)---------------------------------------------------------------------44 in lbs
Cylinder head mounting bolts
1- All bolts---------------------------------------------------------------------------------66 ft lbs
2- long bolts-------------------------------------------------------------------------------89 ft lbs
3- tighten all bolts--------------------------------------------------------- additional 90 degrees
Exhaust manifold--------------------------------------------------------------------------32 ft lbs
Exhaust outlet pipe-v band clamp--------------------------------------------------------72 in lbs
Exhaust pipe clamp mounting-------------------------------------------------------------20 ft lbs
Exhaust pipe steady rest mounting to trans---------------------------------------------50 ft lbs
Fan clutch mounting / fan hub (left hand threads)--------------------------------------42 ft lbs
Fan hub bracket mounting----------------------------------------------------------------18 ft lbs
Fan hub bearing retaining cap screw-----------------------------------------------------57 ft lbs
Fan pulley to fan hub-----------------------------------------------------------------------7 ft lbs
Fan pulley crankshaft-----------------------------------------------------------------------7 ft lbs
Fan shroud mounting nuts----------------------------------------------------------------95 in lbs
Flywheel bolts----------------------------------------------------------------------------101 ft lbs
Flywheel housing adapter-----------------------------------------------------------------44 ft lbs
Front engine mount isolator mounting to mount----------------------------------------80 ft lbs
Front engine mount through bolt---------------------------------------------------------30 ft lbs
Front engine mount to block--------------------------------------------------------------44 ft lbs
Front oil filler pipe-access cover-----------------------------------------------------hand tighten
Fuel banjo screw (in fuel pump)----------------------------------------------------------24 ft lbs
Fuel banjo screw (in head)----------------------------------------------------------------18 ft lbs
Fuel banjo screw (in injector)--------------------------------------------------------------6 ft lbs
Fuel filter--------------------------------------------------------------------half turn after contact
Fuel heater assembly mounting-----------------------------------------------------------24 ft lbs
Fuel heater ground mounting to intake manifold------------------------------------------9 ft lbs
Fuel link fitting (high pressure)-----------------------------------------------------------18 ft lbs
Fuel low pressure supple------------------------------------------------------------------18 ft lbs
Fuel pump drive gear (with pump unlocked)---------------------------------------------48 ft lbs
Fuel pump lock (bosch)-------------------------------------------------------------------22 ft lbs
Fuel pump mounting mount---------------------------------------------------------------18 ft lbs
Fuel pump solenoid------------------------------------------------------------------------32 ft lbs
Fuel pump support bracket----------------------------------------------------------------18 ft lbs
Fuel pump unlock (bosch)-----------------------------------------------------------------10 ft lbs
Fuel vent screw (in banjo)------------------------------------------------------------------6 ft lbs
Gear cover---------------------------------------------------------------------------------18 ft lbs
Gear housing - to - block------------------------------------------------------------------18 ft lbs
Injector retaining nuts---------------------------------------------------------------------44 ft lbs
Intake manifold cover---------------------------------------------------------------------18 ft lbs
Intercooler attaching bolts----------------------------------------------------------------17 in lbs
Intercooler duct clamp nuts--------------------------------------------------------------72 in lbs
Lift pump mounting------------------------------------------------------------------------18 ft lbs
Lifting bracket (rear)----------------------------------------------------------------------57 ft lbs
Main bearing cap bolts
Step 1--------------------------------------------------------------------------------------45 ft lbs
Step 2--------------------------------------------------------------------------------------88 ft lbs
Step 3-------------------------------------------------------------------------------------129 ft lbs
Craw
Craw
Western, Idaho
2013 Sport
HEMI 5.7
Oil cooler assembly------------------------------------------------------------------------18 ft lbs
Oil fill tube bracket------------------------------------------------------------------------32 ft lbs
Oil filter----------------------------------------------------------------------3/4 turn after contact
Oil pan drain plug--------------------------------------------------------------------------60 ft lbs
Oil pan mounting--------------------------------------------------------------------------18 ft lbs
Oil pressure regulating plug---------------------------------------------------------------60 ft lbs
Oil pressure sender / switch--------------------------------------------------------------12 ft lbs
Oil pump mounting------------------------------------------------------------------------18 ft lbs
Oil suction tube (flange)-------------------------------------------------------------------18 ft lbs
Oil suction tube brace---------------------------------------------------------------------18 ft lbs
Power steering pump to vacuum pump mounting---------------------------------------18 ft lbs
Radiator hose clamp - upper--------------------------------------------------------------35 in lbs
Radiator mounting nuts-------------------------------------------------------------------95 in lbs
Rear seal mounting-------------------------------------------------------------------------7 ft lbs
Refrigerant compressor lines - flange mounting-----------------------------------------15 ft lbs
Refrigerant compressor mounting--------------------------------------------------------35 ft lbs
Rocker lever nut-------------------------------------------------------------------------- 18 ft lbs
Rocker support-----------------------------------------------------------------------------18 ft lbs
Starter mounting--------------------------------------------------------------------------32 ft lbs
Starter battery (positive) cable nut-------------------------------------------------------16 ft lbs
Starter solenoid nut-----------------------------------------------------------------------44 in lbs
Tappet cover / fuel drain line supports---------------------------------------------------18 ft lbs
Thermistor---------------------------------------------------------------------------------18 ft lbs
Thermostat housing----------------------------------------------------------------------- 18 ft lbs
Throttle bracket mounting to mounting bracket-----------------------------------------18 ft lbs
Throttle rod mounting to throttle lever nut----------------------------------------------7.5 ft lbs
Timing pin flange mounting---------------------------------------------------------------44 in lbs
Torque converter access cover plate mounting------------------------------------------35 in lbs
Transfer case linkage bracket mounting / trans-----------------------------------------30 ft lbs
Transfer case mounting to transmission-------------------------------------------------35 ft lbs
Trans cooler tubing mounting to oil pan flange------------------------------------------18 ft lbs
Trans kickdown cable bracket mounting / trans-----------------------------------------50 ft lbs
Trans mount mounting to trans (manual)------------------------------------------------50 ft lbs
Trans mount through bolt mounting (manual)-------------------------------------------50 ft lbs
Transmission mounting to engine--------------------------------------------------------30 ft lbs
Transmission oil cooler line connection---------------------------------------------------40 ft lbs
Transmission oil cooler line flange--------------------------------------------------------50 in lbs
Transmission oil to air cooler hose clamps-----------------------------------------------18 in lbs
Transmission to clutch housing mounting------------------------------------------------35 ft lbs
Transmission torque converter mounting------------------------------------------------35 ft lbs
Turbine housing-----------------------------------------------------------------------------8 ft lbs
Turbo compressor housing clamp--------------------------------------------------------75 in lbs
Turbo mounting nut-----------------------------------------------------------------------24 ft lbs
Turbo oil drain tube------------------------------------------------------------------------18 ft lbs
Turbo oil supply (both ends)--------------------------------------------------------------11 ft lbs
Vacuum pump mounting--------------------------------------------------------------------7 ft lbs
Vacuum pump to gear housing mounting------------------------------------------------57 ft lbs
valve cover---------------------------------------------------------------------------------18 ft lbs
Vibration damper mounting---------------------------------------------------------------92 ft lbs
Water hose clamps----------------------------------------------------------------------- 35 in lbs
Water inlet connection---------------------------------------------------------------------32 ft lbs
Water pump mounting--------------------------------------------------------------------18 ft lbs
Water temperature sensor----------------------------------------------------------------37 ft lbs
Craw
Craw
Western, Idaho
2013 Sport
HEMI 5.7
Chassis Torque Specs
(4th Gen RAM)
Shock Absorber Upper Nut --------------------------------------------------------------40 ft lbs
Shock Absorber Lower Bolt -------------------------------------------------------------100 ft lbs
Shock Tower to Frame -------------------------------------------------------------------55 ft lbs
Lower Ball Joint Nut Initial Torque------------------------------------------------------ 35 ft lbs
Lower Ball Joint Nut Final Torque ------------------------------------------------------148 ft lbs
Upper Ball Joint Nut -----------------------------------------------------------------------70 ft lbs
Lower Control Arm Frame Nuts --------------------------------------------------------200 ft lbs
Lower Control Arm Axle Nut------------------------------------------------------------ 200 ft lbs
Upper Control Arm Frame Nuts --------------------------------------------------------120 ft lbs
Upper Control Arm Axle Nut ------------------------------------------------------------120 ft lbs
Stabilizer Bar Frame Bolt ----------------------------------------------------------------45 ft lbs
Stabilizer Link Axle Bracket------------------------------------------------------------ 110 ft lbs
Stabilizer Link Stabilizer Bar Nut --------------------------------------------------------27 ft lbs
Stabilizer Link Axle Bracket (Power Wagon)------------------------------------------ 110 ft lbs
Stabilizer Bar Nut (Power Wagon) -----------------------------------------------------110 ft lbs
Hub/Bearing Bolts -----------------------------------------------------------------------149 ft lbs
Axle Nut - 132 ft lbs Beginning Torque, Then Rotate 5 to 10 ~ Times With a Final Torque of 263 ft lbs
Track Bar to Frame (2500/3500 4x4) -------------------------------------------------200 ft lbs
Track Bar to Axle (2500/3500 4x4) ----------------------------------------------------200 ft lbs
Tie Rod End Nut ---------------------------------------------------------------------------55 ft lbs
ABS Assembly Mounting Bolts -----------------------------------------------------------11 ft lbs
ABS Assembly ABM Screws -------------------------------------------------------------31 in lbs
ABS Assembly Brake Line Fittings -----------------------------------------------------170 in lbs
Dynamics Sensor--------------------------------------------------------------------------97 in lbs
Wheel Speed Sensors, Front Sensor Bolt ----------------------------------------------190 in lbs
Wheel Speed Sensors, Bracket To Knuckle ---------------------------------------------60 in lbs
Wheel Speed Sensors, Rear Sensor Stud--------------------------------------------- 200 in lbs
ABM Mounting Screws --------------------------------------------------------------------53 in lbs
RWAL Module Mounting Bolts ------------------------------------------------------------11 ft lbs
RWAL Valve Brake Line Fittings --------------------------------------------------------170 in lbs
Rear Wheel Speed Sensor Mounting Bolt ----------------------------------------------200 in lbs
Brake Booster Mounting Nuts ------------------------------------------------------------21 ft lbs
Master Cylinder Mounting Nuts ---------------------------------------------------------160 in lbs
Reservoir Retaining Screws ----------------------------------------------------------------6 ft lbs
Caliper Bleed Screws ---------------------------------------------------------------------14 ft lbs
Caliper Mounting Pins, Front -------------------------------------------------------------24 ft lbs
Caliper Mounting Pins, Rear --------------------------------------------------------------22 ft lbs
Caliper Adapter Mounting Bolts, Front (1500) -----------------------------------------130 ft lbs
Caliper Adapter Mounting Bolts, Front (2500/3500) -----------------------------------275 ft lbs
Caliper Adapter Mounting Bolts, Rear (1500) ------------------------------------------120 ft lbs
Caliper Adapter Mounting Bolts, Rear Upper (2500 and 3500) ----------------------163 ft lbs
Caliper Adapter Mounting Bolts, Rear Lower (2500 and 3500) ----------------------190 ft lbs
Junction Block Bolts, Front (1500) -------------------------------------------------------14 ft lbs
Junction Block Bolts, Rear (1500) --------------------------------------------------------18 ft lbs
Junction Block Bolts, Rear (2500/3500) ------------------------------------------------7.5 ft lbs
Brake Pedal Assembly Bracket Bolts (1500) --------------------------------------------23 ft lbs
Brake Pedal Assembly Bracket Nuts (2500/3500) --------------------------------------21 ft lbs
Support Plate Mounting Bolts/Nuts (1500) ----------------------------------------------75 ft lbs
Support Plate Mounting Bolts/Nuts (2500/3500) -------------------------------------150 ft lbs
Brake Line Fittings, Master Cylinder -----------------------------------------------------14 ft lbs
Brake Line Fittings, Junction Block (Both) -----------------------------------------------14 ft lbs
Caliper Brake Line Banjo Bolt, Front -----------------------------------------------------20 ft lbs
Caliper Brake Line Banjo Bolt, Rear ------------------------------------------------------20 ft lbs
Brake Hose Bolts To Frame, Front ------------------------------------------------------7.5 ft lbs
Brake Hose Fitting ------------------------------------------------------------------------14 ft lbs
Parking Brake Pedal Assembly (1500) ---------------------------------------------------18 ft lbs
Parking Brake Pedal Assembly (2500/3500) -------------------------------------------14 ft lbs
Hub/Bearing Bolts (1500) ---------------------------------------------------------------120 ft lbs
Rotor to Hub Bolt, Rear (2500 and 3500 DRW) ---------------------------------------114 ft lbs
Extension to Rotor Nut, Front (2500 and 3500 DRW) --------------------------------128 ft lbs
Hub/Bearing Bolts, Front (2500 and 3500 4X2) ---------------------------------------130 ft lbs
Pitman Arm Gear Shaft Nut (2500, 3500) ---------------------------------------------177 ft lbs
Drag Link to Pitman Arm (2500, 3500) ------------------------------------------------100 ft lbs
Drag Link to Tie Rod (2500, 3500) -----------------------------------------------------100 ft lbs
Drag Link Adjuster Clamp (2500, 3500)------------------------------------------------- 40 ft lbs
Tie Rod End to Knuckle (2500, 3500) ---------------------------------------------------78 ft lbs
Tie Rod End Adjuster Clamp (2500, 3500) ----------------------------------------------40 ft lbs
Stabilizer Bar Link to Axle (2500, 3500) -------------------------------------------------50 ft lbs
Steering Damper to Axle or Linkage(2500, 3500) -------------------------------------75 ft lbs
Steering Damper Bracket U-Bolt Nuts (2500, 3500) ------------------------------------45 ft lbs
Track bar to Axle - M16 fastener (2500, 3500) ----------------------------------------200 ft lbs
Track Bar to Frame - M16 fastener (2500, 3500) -------------------------------------200 ft lbs
Lug Nut 9/16 X 18 with 60° Cone ------------------------------------------------------130 ft lbs
Lug Nut 9/16 X 18 with 60° Cone (2500, 3500 - SRW) -------------------------------140 ft lbs
Lug Nut 9/16 X 18 with Flat Washer (3500 - DRW) ----------------------------------145 ft lbs
Lug Nut 9/16 X 18 with Flat Washer (4500, 5500 - DRW) ----------------------------148 ft lbs
Spare Tire Winch --------------------------------------------------------------------------15 ft lbs
Jounce Bumper Bolts ------------------------------------------------------------------21.5 ft lbs
Shock Absorber, Lower Nut/Bolt --------------------------------------------------------100 ft lbs
Shock Absorber, Upper Nut/Bolt -------------------------------------------------------100 ft lbs
Spring Clamp U-Bolt Nuts --------------------------------------------------------------110 ft lbs
Spring Front Nut/Bolt to Frame ------------------------------------------------------254.5 ft lbs
Spring Shackle Nut/Bolt, Upper/Lower -------------------------------------------------160 ft lbs
MADDOG
Living in a Firepit
I would check with the person who posted the specs or independently verify them with a service manual.
BWL
Embrace the skeptisism
BC Canada
That's a lot to check, but if it turns out they're accurate this will be a thread worth saving for future reference.
Craw
Craw
Western, Idaho
2013 Sport
HEMI 5.7
Anyone have a manual laying around lol
Ramnewbie
To the OP, I would go with the 150# wrench. You'll have very little use for the upper end of the 250# one and loose a substantial amount of you're lower end torque values. I've got an inch pound and a 150# and can't ever recall needing or wanting anything else. I'm not saying you will never need the 250# one, however you'll have very little if any use for it.
OCDTech
Louisiana
The money is a good reason for going with a bigger wrench, heres another, I was told never max out your wrench. I see one spec there is for 129 lbs. Not max but getting there. There may also other bolts pretty tight, I think pinion nuts can be high torque at times. I had an axle nut on my Subaru called for 149. I bought the big wrench for that. Although Ramnewbie has a good point, the lower end would be of great concern. I know you may not can afford both but i had no choice. So may want to get the 150 and wait until you really need the 250 like i did.
