Is this sport hood worth $250 ??
ilovemyramlaremie
Moravia NY
D86CB844-A2BC-419B-AFBB-CCFDFBEECD59.png 4BB1C5BA-9A2F-415F-93A5-9FC9E070DE4D.png D86CB844-A2BC-419B-AFBB-CCFDFBEECD59.png Is this sport hood worth the $250??
With this small dent in the front.
It’s off a 17 rebel, are those hoods aluminum or steel??
Thanks
Pull Ya
Cedar Creek, Tx
Depends on whether or not you have a good friend that does body and paint work and whether it's buckled in the middle from the impact.
Jay
MK96
SK
If it is aluminium I'd stay away. Bringing it back to shape it might crack.
LugsLeadOut84
NYC Suburb
Think of it this way....There's a reason it was removed from it's original vehicle and replaced. Being it's aluminum, it's probably not feasible or is too much trouble to properly fix. Cheaper/easier to replace, which is why you're being given a great deal of "only $250".
Unless you have a friend in the body shop business, you'll be sinking at least $500 to fix, maybe more. OEM hoods go for around $1100.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
when I had my little incident with my truck and garage wall, they replaced the hood because you can't properly repair aluminum. just sayin
rule18
Admin
NY
2017 Rebel
I'd pass. Someone probably already told the seller that it will crack which is why he's selling. :Pshyco:
RamRMK
Vt
Nope pass. Aluminum can be repaired however usually dual walled areas can not. The dent is on the front two body lines and more than likely goes into the front underside structure.
svs9007
I've got a stock hood off 2011 Laramie. White, no dents or Nick's. Make me an offer.
boblonben
ReefRaider
You chose wisely . The hood is repairable. Would take a good two days to put in primer. The biggest thing is unless your set up to work on AL. Its easier to just stay away from it.
I have all the certification to work AL on fords. Couldn't get far enough from them.
Dusty
Rochester, New York
After purchasing my 2019 Ram I called my insurance rep and asked why my insurance rate went up $240. The first thing she said was, "Is it a Ford?"
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Now at: 008323 miles.
