shibby927
- Feb 18, 2012
- 1,687
- 460
- Location
- The Great State of Iowa
- 2021
- 5.7L Hemi
So I have an issue and could use some help from one of you lighting gurus or electrical geniuses. Basically I tinted my tails and to compensate for some of the light output lost with the stock bulbs in tinted housings I bought a couple of 45 LED taillight bulbs from super bright leds. I'm no expert in this stuff so I bought them, installed them, and quickly found that the truck didn't like them very much.
They light up like normal but at first the only one that would blink when I used my signal was the passenger side. I found that the driver side one wouldn't blink at all and that when I press my brakes it is causing the front driver side turn signal marker to light up? Pretty strange I guess, but again not very good with this stuff.
So I ended up buying resistors as I understand that LEDs aren't recognized because they put out less than a standard halogen bulb. Installed the resistors and I'm still having the same issue. The passenger side works fine and the driver's side is doing the same thing as before. The only difference now is that my EVIC isn't telling me that either one of my turn signal markers are out.
Any help would be appreciated. Thank you in advance!
