Matt got it right, sort of,
But there are several examples in that link,
only the first was a Supercharged 500HP+ Vette
Read a little further There's a fairly stock Gen5 372HP NA Camaro SS, with similar results
Originally Posted by Jason 98 TA
After 5 days of engine dyno testing different combinations & packages I'm proud to announce I finally have some extra time to provide you guys with some of the information we've learned!
The very first dyno testing we did compared header primaries & power output from 3000 to 6000rpm. The base engine was completely stock 01 engine with only a Fast intake installed. We dyno tested both the Pacesetter 1 3/4" coated long tubes & the TSP 1 7/8" long tube headers. The goal was to see how the larger primaries would effect power on a basically stock engine. To my suprise the 1 7/8" headers made a considerable amount more power than the 1 3/4" headers! Power output was virtually identical untiL 4800 rpm when the 1 7/8" headers began to outpower the smaller 1 3/4" primaries. The 1 7/8" headers made a peak hp of 414.x hp & 421lb ft while the 1 3/4" headers made 408hp & 419 lb ft of torque. While this isn't a huge difference,
it definately shows that even on a basically stock car the larger headers are still a good investment! Power under the 4800rpm point was virtually identical! Infact the 3000 rpm numbers were 209hp 366 tq from the 1 3/4" headers & 209hp 359.9 tq!
Both dyno runs were backed up several times & the combos used very similar air fuels & locked in timing at 28 degrees. I thought this was a pretty cool comparision, because the common thought is the 1 7/8" headers is just overkill on anything smaller than stroker setups. This is apparently not the case....
Here's a few pics of the 1 7/8" headers installed on the engine dyno
This is the area that seems to cause the most confusion but it is fairly straight forward. Header manufacturers usually offer two or three options when is comes to primary diameters for a specific vehicle. For example, for the new 5th generation Camaro SS most manufacturers are offering 1 3/4 inch, 1 7/8 inch, and 2 inch primaries. Here are the results of some recent back-to-back testing on an otherwise stock SS:
Stock: 372 RWHP 376 RWTQ
1 3/4 headers with high flow cats: 401 RWHP 404 RWTQ
1 7/8 headers with high flow cats: 408 RWHP 409 RWTQ
2 headers with high flow cats: 413 RWHP 410 RWTQ
and yes there are Ram's that successfully run 1-7/8" LT's
Fastest NA Ram , Ethan (greychevy) has 1-7/8" ARH's LT's
4.56's and 3000 stall put him at the top of the list.
12.801 @ 103.63 - 2012 1500 RCSB 4WD 5.7L - N/A - GreyChevy - 01/24/14
That's what I'm running on my truck. I was concerned as well but the results speak for themselves.
