Just ordered from Moe's
jcsedrn2
Sayre, PA
First Mod was window tint 5% all around. Next set of Mods - S&B cai with scoop, 87mm TB, BT catch can, and DS Trinity tuner all ordered 10min ago. Still trying to decide on which exhaust to go with, want the performance and nice rumble but not wanting in cab drone, any help.
Berber5985
I ordered all of the above except mine is vararam, trinity tuner, 87mm tb, and then the mufflex magnaflow 14" exhaust. Just those mods alone woke my truck up significantly in both sound and go. Next mod will be catch can and 180 t stat. Then ar headers
BlkRamRt
SoCal
HEMI 5.7
do you want to change the muffler only? if so then go with the 18 inch magnaflow.
jcsedrn2
jcsedrn2
Sayre, PA
No it is outdoorsman with single exhaust with exit behind pass rear tire, would like to go duals with side exit behind rears.
Hammer75
Kansas
I got the side exit, I went with a single in dual out Magnaflow 14" and have no drone in my cab unless I hit 81 mph. Sounds good otherwise, I also run the S&B Intake, and will soon have the magnaflow Y pipe.
I originally had a Flowmaster super 40 on it and I would not recommend it, it robbed me of throttle response.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
I have the S&B love it. 85mm TB will come later and a mufflex 18" magnaflow bolt on.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Thank you Jay. As for the exhaust, Magnaflow makes a catback system with a dual side exit that uses the 18" muffler that was recommended above. This setup is definitely noticeable when you are heavy on the throttle, but it is tame on the highway to make for a more comfortable drive.
Magnaflow Catback Exhaust 2009-2013 Dodge Ram 1500 Dual Side Exit Catback Exhaust 18" Muffler with Dual 3.5" Polished Stainless Tips
If you want to add your own tips and have a shop weld everything up, then you can go with just the universal muffler. Only real drawback to this is that most shops wont use stainless piping, and the aluminized that is normally used will rust out quickly...especially with the salty PA roads in the winter.
jcsedrn2
jcsedrn2
Sayre, PA
lookin for duals that exit out driver and pass sides behind rear wheels
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Take a look at the MBRP kit below...
MBRP Performance Exhaust
This kit is available in aluminized steel for $424.99 or in 409 stainless steel for $564.99. I do not have these on the website yet, but I will work on getting these added today.
jcsedrn2
jcsedrn2
Sayre, PA
Got my DS trinity today from ups guy, awesome..... can't get it to download on my computer, get all the way thru to downloading the dsdownloader part and it seems to run through the download twice and then says 2nd install wizard will finish download then it tells me to plug programmer in and I do, go thru steps like on video and get to the files on my computer and there is nothing in file it says it downloaded to and cant get trinity registered or anything from there...... Help someone please.
