Late model 5.7 coil packs?
Rumblebee
Anybody ever converted their older model truck with the coil on plug and spark plug wire to the ones that sit on both spark plugs?
charonblk07
Calgary, Ab
F1-A forged 349ci
You need the '06-'08 valve covers and ignition coils, then you can either cut and wire in the new coil plugs to your existing harness or pick up an adapter set.
R
Rumblebee
So it's just a simple swap out? No need for a re-tune or re-flash?
ATXHEMI
Round Rock Tx
No re-tune needed. This pic is my 05. There are plug and play adapter available. No cutting into the factory harness. Excuse the Orange bolts. Lol the valve covers were that color when I got them.
R
Rumblebee
So the bolts on the valve cover are on the opposite location of the ones that are on there now. The question is, does it have to be ram valve covers/coil packs or will the car version work?
charonblk07
Calgary, Ab
F1-A forged 349ci
Car ones will work just fine, just make sure it's the covers with 2 holes for each coil and they are the pre-eagle covers, not the '09+ ones.
R
Rumblebee
Thanks for the help guys. Gotta go scrounge around the salvage yards now.
