Led headlight flicker
Ro2id
Need help use bouggt h13 led liggt and installed them and all they do is flicker then shut off what can i do to correct this plz help
ramportin1
Sickest member here
Oregon
LED or HID? Rams have a cannbus system and require a constant power draw otherwise will trigger a lamp out and shut your lights off. To do that you have to get 2 capacitors and splice them into the trucks harness's so that it reads a constant draw.
ramportin1
Sickest member here
Oregon
warning cancellor anti flicker capacitors, they make these that are supposed to be plug and play for both HID and LED kits. Though they did not fix my HID 's and I had to splice into my harness
ramportin1
Sickest member here
Oregon
Resistors, you also need resistors. Sorry I spaced that and it just popped in my head. Anti flicker capacitor harness and resistors. Resistors must be mounted to bare metal and will get very hot when in use so mount accordingly. Here's one of mine 0a6b2984ea4088626769693051e4ca63.jpg
Jcarlosm196
https://www.amazon.com/gp/aw/d/B01KMB9IRC/ref=oh_aui_i_d_old_o0_img?ie=UTF8&psc=1
Thats the ones that solved my problem the ones that came with mine didnt work, one of the ones ordered above were defective and they replaced them free of charge, only thing you cant listen to radio and have lights on at the same time all you hear is interference lol
