Led Headlight Help.
RamHemi2500
North jersey
2015 ram 1500
I bought a 2015 Ram Express 1500 with the crew cab. it did not come with the illuminated mirrors along with the LED headlights as seen on other models. if i buy these items after the fact will it still work with my current truck? also if i buy the ed headlights can i change the color in the parking lamps from yellow to white like the newer Durangos. i like that look better.
jasonw
South Dakota
3.0L Hurricane HO
The headlights will work, but if you want it easy, you'll need an adapter wiring harness. Jeremy @ Retro Shop Online Store has a lot of what you might need, and he does custom work like making the LEDs white, or switchback style (white and flashes orange for signal, or vice versa).
BlownGP
Houston/Baton Rouge
They will work and will need the adapter.
Changing the turn signals lights is going to be a little harder. Going to need a whole new LED board. It's not just some bulbs you can switch out.
