LED Light Question
Cruizer
Ohio
2010 Sport 4x4 QC
I've never seen this discussed before, so I thought I'd ask. If you buy a set of LED tail lights, what happens when an LED goes out? Regular tail lights, you just replace the bulb. Can you replace a single LED easily? Is it easy to find an LED that matches your lights? I know LED's last much longer than the standard light bulb, but I'd like to know what I might get myself into before I buy aftermarket lights.
ducatiram
hemi
from what I understand once it's out, it out, you need to replace the whole thing. But most quality led's will outlast your truck.
emjohn4
I'll let you know when an LED from my 2013 tails burns out. It might be a while. :)
Now, ebay lights? It's a gamble, due to spotty China quality, but generally LED's last "forever."
Cruizer
Cruizer
Ohio
2010 Sport 4x4 QC
Thanks for the info. Sounds like its not a big problem. :D
Cthulhu
Calgary, AB
Cummins 5.9
I have a set of KC LED Driving lights.. They perform very well but I lost the bottom half of one array (~10 LEDs) and I'm assuming they are wired in series. I have not dug into the head to see if that can be remedied in any way but ya, they likely are wired in series in other heads too for performance...
I had them on my truck ~2.5 yrs.
gmzvip23
2k12
most leds are sodered on board i so its easier to just replace the whole piece.
tunedwhitey
chicago, il
2003 dodge ram
U could replace that one led if u no how it is cheaper but ur better off replacing the whole thing
Sent from my SGH-M919 using Tapatalk 2
Stangshcky12
Oshkosh, WI
5.9 Cummins
Theyre a ***** to get apart
I had a pair, one side only had a running light and no brake light while the other just fell of the truck cause the mounts were flimsy
BlownGP
Houston/Baton Rouge
Yup, you cant replace them..
I mean you could if you know how to solder, but it wouldn't be worth the time.
