Led third brake light options
ADUBIS
Virginia
3.6 Pentastar
Replaced my stock tail lights on my 16 Tradesman this weekend with leds that came with load equalizers wired into Them. There are no bulb out messages. Now I am on the hunt for an led third brake light/cargo light. Wondering if there are brands that include the load equalizer and would I need one since both tail lights already have them?
San Ysidro, CA
3.6 Pentastar
My 2014 Tradesman has had LEDs on the 3rd brake light and cargo lights for the last 6 months without issues. You only need to search for Canbus error free 921 LEDs and you're set.
These are the ones I got back then (also used on the backup lights)
https://www.ebay.com/itm/28343156945345f0fb09ea91f8b14c43ce5e7360d6dd.jpg
Sent from OnePlus 7 PRO using Tapatalk
Boston, MA
2014 Crew Cab
5.7L V8 HEMI
3rd brake light I have VLEDS 921 high power Red LED.
https://www.vleds.com/shop-bulb-numbers/921-led/921-6-r.html
Cargo lights I have VLEDS 921 high output 5500K LED.
https://www.vleds.com/shop-bulb-numbers/921-led/921-36-w-5500k.html
I have these 921 high output 6K White for my reverse.
https://www.vleds.com/shop-bulb-numbers/921-led/921-6-ho-c.html
All plug & play and give no dash error message. Come with 3 year warranty if they fail. Note: always put same color LED behind same color lenses for deep vivid color. Example: Red behind Red lenses.
ADUBIS
ADUBIS
Virginia
3.6 Pentastar
I was looking for a complete sealed third brake light but the bulb thing is looking like a good possibility as well. Especially the reverse light bulb. My back window has a dark tint and it gets hard to see when backing up. I don’t want to install a back up camera either.
NJMOPAR
Older and faster
ELizabeth, NJ
Invest $5 in a new gasket for the 3rd light.
Vipmotoz makes one that's double sided adhesive.
And don't lose the washers for the two screws holding it on, they're a potential leak point.
ADUBIS
ADUBIS
Virginia
3.6 Pentastar
Good tip. I’ve heard that it’s a potential leaky spot from the factory
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
yea I tinted by 3rd brake light, it doesn't leak, so didn't wanna start a potential one LOL
BBhorn
Long Island NY
I decided to try an Amazon special. Dont get this one. The white cargo light stays on all the time. Every time I press the brake it comes on and doesn't go off. Too bad cause I like how it looks. Screenshot_20200521-212849_Amazon Shopping.jpg
