- Joined
- Nov 9, 2016
- Posts
- 2,783
- Reaction score
- 5,944
- Location
- Montana, officially RETIRED
- Ram Year
- 2014
- Engine
- Hemi 5.7, supercharged
So I spent 12 hours in the truck today driving from Minneapolis Minnesota to Glendive Montana coming from visiting my daughter.
Started out at 630 it was 3 degrees, ended up in Montana at 30 degrees, lots of snow but clear roads and low traffic.
My opportunity was to observe the gauges on my 24 Ram 1500 Classic. As the temp was below 10 degrees the oil and coolant temp consistently displayed 199 to 201, never over 201, while the transmission temp displayed 147 to 149
( I have the @caulk04 trans device installed) Heat in the cab on auto was a constant 72, but if you flipped on the defrost it felt like it soared to 78 or 80 and became almost unbearable, but when this happened the trans temp dropped to 145.
When the outside temp went above 10 to about 20, the coolant temp went up to 203 and settled (thermostat operating temp) and the engine oil temp went up to 210, while the trans temp dropped to 138.
Over 20 to 30, coolant temp 203, engine oil temp 215, transmission temp dropped to 131, and rose only slightly as the truck on cruise control downshifting to climb moderate hills on the freeway.
I was amazed that the truck and I can only assume the 3 way valve was smart enough to isolate various engine systems and heat the components that required heat when needed.
I know several members here have removed the 3 way valve and used the older 6 speed hoses, I think, that's allowed the coolant to flow differently.
I'm not certain I understand exactly how this works but it was fascinating to watch and learn how this system works. If that truly what caused the change in temperature that I noticed.
Thoughts on this?
is this the way the valve works, or was I bored out of my head and just noticed random data points and should find a hobby,, like chewing gum or singing along with the radio.
Thoughts on this?
