275/65/r20. They did rub a tiny bit when locked out before it was leveled.What size coops?
Does your Ram have the ORP?275/65/r20. They did rub a tiny bit when locked out before it was leveled.
What is ORP?Does your Ram have the ORP?
What is ORP?
it did not.The "off road package" which I believe came with a small lift (1"?) and all terrain tires, among some other things.
thanks for the quick response! I checked out two places by me. One place wanted to install the set you have and other one wants to a Rough Country leveling kit. Any thoughts or heard anything about the Rough County? First time truck owner and I have no clue. Currently I have stock wheels (275) and they said I could put on 33/11/50R20 Nitro's. Thoughts on that? Appreciate your time and thoughts
I’d say the best product possible would be the new Falcon kit or the Icon coilover kit. Unless you’re only after the look, then the bilstein 5100 is the way to go. I’d get new UCA though to take the stress off the upper ball joint.Thanks for all your assistance with this. With so much out there and my first truck I just wanted to make sure I was getting the best product possible
without the control arm upgrade I was worried it puts the ball joints at a less then ok angle causing premature failure?
Is the new falcon kit out yet? If so where at?I’d say the best product possible would be the new Falcon kit or the Icon coilover kit. Unless you’re only after the look, then the bilstein 5100 is the way to go. I’d get new UCA though to take the stress off the upper ball joint.
