Do you not drive your truck when it's too cold outside because your wheel bearings might fail? Do you loose any sleep over your wheel bearings? You might, if they were made in Turkey, or Bulgaria, or some other obscure place where parts are manufactured for cheap European cars, like... FIAT, Peugeut, Citroen, Renault, Opel, and so on.It could very well be weather related, how many guys up in Alaska are having the same failures? Or the opposite end of the scale and the guys down south in the heat? Are they also having the same rate of failures?
Roller lifters are mass produced, and generally speaking, they haven't been an issue for Hemi engines for a long time, or up until Chrysler was sold to Cerberus Private Equity Group. It was around the same time as the Hemi got VVT added to it. The engineers redesigned the new Hemi around 2008 with a forged cam, but it didn't make the final cut, just like decent lifters were now a thing of the past in favor of cheaper ones. There is plenty of proof of that, your case being one.
Set some money aside, and when you're out of warranty and this happens again, get a set of Johnson lifters, a Comp Cam, and maybe new & improved push rods. If you're well north of 100K miles, get new valve springs as well.
Take a look at the following video. Abused Hemi, sludged up, spun bearings, a rod went through the block, almost 200K miles. Not a single bad lifter. What does that tell you?
Here: https://youtu.be/2nTVq2Fkhfc
