Locating or Identifying Electrical Connectors
DA67Goatman
Ohio USA
I'm trying to ID some of the factory connectors and acquire mating halves to replace factory harnesses with aftermarket stuff without butchering up the factory harness. I managed to get some injector pigtails to fit the factory license plate light harness. Now I'm trying to locate this half of the large connector just behind the Dr Fr wheel above the framerail.
I am really struggling to ID the connector. I know that it was for the 4 Corner Air Suspension height sensors. Obviously these are sourced from a supplier, but I haven't been able to locate anything other than full harnesses, which is what I removed already. Anyone have inside info or a source that can help me?
DA67Goatman
DA67Goatman
Ohio USA
Thank you. Now I have a mopar number to reference. I never knew such a site exists
Jeepwalker
WI
2012 Reg Cab, 4x4
There are quite a few odd connectors (new) on ebay I noticed when I was working on a project last yr.
Jeepwalker
WI
2012 Reg Cab, 4x4
Looks like a real vulnerable place for a bundle of wires to cross under the middle of the frame, between the wheels. I hope the fuel pump wiring isn't somewhere in those wires.
