What made them fail?? LOL
An inattentive Phord driver...
I hate that so bad for you. Probably on a phone. Good luck.An inattentive Phord driver...
I have them. No issues so far. I used alfaobd to configure the hid setting and they've worked perfectly since day 1. I bought the mid range ballast (plus?) And upgraded bulbs. Less than $80 USD out the door not including alfaobd
Sent from my SM-G935F using
Tapatalk
Not required. It reduces the clutter associated with hid. It removes the pulse width modulation (PWM) flickeringIs this alphaobd a must if converting to hid's?
Sent from my SM-G935F using Tapatalk
i got a 2015 ram sport with spyder headlights....but my OEM ones were factory projector....ive had my HID kit in for awhile but i keep running into issues with my ballasts going out and bulbs etc....im looking to convert them to LEDs'....will this kit work correctly? or would i need something else to not get a flicker etc... link below of the LED kit.
https://www.amazon.ca/RCP-Headlight...ds=H1+LED+KIT&qid=1555175519&s=gateway&sr=8-3
I installed the Hikari 2019 new gen LED bulbs in my Fogs and Low Beams. No error codes and no flicker. LED Lows have same cut off as the halogens. I've had them a couple weeks now and very happy with the improvement.
