low beam LED upgrade....sick of HID's....
Cableman
Longisland
I have them. No issues so far. I used alfaobd to configure the hid setting and they've worked perfectly since day 1. I bought the mid range ballast (plus?) And upgraded bulbs. Less than $80 USD out the door not including alfaobd
Sent from my SM-G935F using
Tapatalk
Is this alphaobd a must if converting to hid's?
fyreman
SW America
Not required. It reduces the clutter associated with hid. It removes the pulse width modulation (PWM) flickering
Sent from my SM-G935F using Tapatalk
Cableman
Longisland
Ah ok. Maybe ill to the ddm ultra canbus for longer lifespan. If the 9011s were cheaper id prolly go that route but 50 bucks for 2 of them i may as well do the hid's
BrewCrew
Lake Arrowhead
HEMI 5.7L
i got a 2015 ram sport with spyder headlights....but my OEM ones were factory projector....ive had my HID kit in for awhile but i keep running into issues with my ballasts going out and bulbs etc....im looking to convert them to LEDs'....will this kit work correctly? or would i need something else to not get a flicker etc... link below of the LED kit.
https://www.amazon.ca/RCP-Headlight...ds=H1+LED+KIT&qid=1555175519&s=gateway&sr=8-3
I just installed the Hikari Ultras and i love them. You will need canbus cancelers. Check out the links below.
Canbus Cancelers
https://www.amazon.com/gp/product/B06WLM6LS5/ref=ppx_yo_dt_b_asin_image_o03_s03?ie=UTF8&psc=1
Hikari LED Ultras
https://www.amazon.com/gp/product/B077B7GJ5J/ref=ppx_yo_dt_b_asin_image_o03_s02?ie=UTF8&psc=1
Todd M Hogan
Pa
I have a set of lumen led color changing app controlled ones for sale
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Got me some Heise H11 and 9006's LED, ordered the black OEM quads, so will install all at once.
Valkyrie0002
Fredericksburg, Va
2017 Big Horn CC
I installed the Hikari 2019 new gen LED bulbs in my Fogs and Low Beams. No error codes and no flicker. LED Lows have same cut off as the halogens. I've had them a couple weeks now and very happy with the improvement.
Razzman
Southern Arizona
2020 Limited CCSB
Let's see some pics
