Low beam not working
Catalin
Calgary AB
3.6L
2015 RAM 1500, 3.6L. Both low beams not working. I checked the Low Beam Headlight Bulbs and replaced them with new ones. No effect. Inspected and verifying the F10 fuse for the conduit. Fuse is OK.
Do you have any thoughts?
Many thanks in advance,
Catalin
turkeybird56
Central Texas
Sounds like bad Headlight Relay Fuse. Is a Black Cartridge, not a regular ATR fuse. Could also be corroded contacts on the relay. U need to have someone turn on lights and U need to listen for relay to click. If no click, relay, usually the cause when both lights are out.
1 URL: https://www.youtube.com/watch?v=ptcqtJg189s
CAVEAT: I am not a mechanic, just a suggestion and the video was pretty good also but may not apply to yer issue
