I should of been clearer. The factory hitch is the piece of tubing that raps around the spare tire and welded to each side of the frame and it also supports the weight of the bumper. After taking the trailer off I lost the sag on the the passenger side, but not completely on the drivers. I'm wondering if taking a brace out for the amp step has anything to do with it. Still curious what our trucks are rated at for tongue weight.Um... A Class 3, 4, or 5 hitch should not be connected to the bumper. If you're loading your hitch and the bumper moves... Somethin' ain't right!
Not saying you may not already know, but just because a hitch has a 2x2 receiver doesn't make it anything other than a 2x2 receiver. The mounting for that little 2x2 hole has to mount solid to the frame, not the bumper/body. And for a Class 5 hitch, that should be one big honkin' solid frame mount.
And a Class 5 hitch is rated at 2550 max tongue weight.
The factory 2.5" Class V receiver is only rated for 1800/18K lbs
As with all the Class of receiver hitches, the maximum tongue weight is when using a WDH.
Despite what some people think about towing with a HD truck, but WDH still needed.
The amp bed step you remove bracing from the bumper to install. The trailer hitch is part of the frame and supports the bumper.. The bumper is bolted to the traditional frame but the bumper brackets are light weight and don't appear to be able stand alone without the weight support of the hitch.. I think I'm just overly nervous because I tore a class IV off of the last generation ram. I don't know how the class v is connected, if its bolted or welded or what. The class IV was 4 bolts into the crossmember and then 2 into the bumper.I don't think the AMP step brace removal would have anything to do with it, all of the AMP is forward of the rear axle. I have an aftermarket ranch-style rear bumper so I can't go underneath to see what braces are where. But I still call foul ball on your bumper moving around when you apply/remove weight from your hitch. I think I would take the truck to a tire dealer, a UHaul, or some other shop with a lift and have them get out a torque wrench on all of your hitch bolts. Or get under it yourself if you're so inclined. Also make sure that if there is a hole, there is a bolt in it. Maybe something is just loose enough to allow movement.
I just can't see how your trailer hitch, which should be installed separately onto the frame from the bumper/body, is moving the bumper.
